The year and other information is always helpful when you're looking for HELP! I'm guessing a '92+ car and likely an LT1 using only the conduit cover for the ECM connectors as a guide. What is the year? There's a grommet/stud/nut arrangement and I don't believe a snapshot will help you but if you mention year I believe I can supply you with a good image.
Try this image and parts 6, 7, 8, 9 for the hardware. Those not listed in the nomenclature aren't available but if you confirm the year I'll supply you with those numbers.
Can't find a part number- was hoping to find that & then cross reference it.
The grommet(#7) is GM# 14104640, spacer/sleeve (#6) is GM 14104639, the bolt is an M8 X 1.25 X 35 and an M8 flanged nut would complete it. '90+ cars should be the same. Assembly may be reversed from that image maybe, not sure. Nut might be on the backside of the assembly or maybe it was reversed in later years.
This shift lever grommet should work for the grommet and you could "adlib" the rest or buy an appropriate sleeve in a good hardware store. GM # 3975131 shift grommet should work + the nut and bolt I mentioned. The grommet is on many dealers shelves.
Very cool, thanks!
I have everything except the rubber iece- will see if I can order that.
