9th injector-- help
Old Sep 13, 2014 | 05:52 PM
ghoastrider1's Avatar
ghoastrider1
Default 9th injector-- help
replaced the injectors today. have a fuel leak where the 9th screws/bolts to the fuel rail. Seems to be coming from the male/female union AND from where the line passes thru the bolt. Took it back apart and put a rubber o ring on the line, still leaks from where the line passes thru the bolt. Can I simply disconnect the line and cap it off? suggestions? thnks.
Old Sep 13, 2014 | 08:17 PM
ghoastrider1
60 folks look and no one has any idea?
Old Sep 13, 2014 | 11:02 PM
aklim's Avatar
aklim
Can you? Absolutely. Will you have hard cold starts? Probably.
Old Sep 13, 2014 | 11:08 PM
Cliff Harris's Avatar
Cliff Harris
What I found on my car was that the bore in the fuel rail had a sharp edge on it that was cutting the O-ring. I sanded the edge off and polished the bore so the O-ring would slip into place without being cut. Never had a leak since then.
Old Sep 14, 2014 | 08:35 AM
ghoastrider1
thnks guys.. gonna have to pull that fuel rail back off and take a look.
Old Sep 14, 2014 | 10:12 AM
JackDidley's Avatar
JackDidley
I ran mine for a couple years with that unplugged. It started funny but not a problem. I think I cranked a couple seconds, gave it 1/2 throttle for a second and then it started. Once started it was all good. Even in single digit temps.
Old Sep 15, 2014 | 12:28 AM
Cliff Harris
This image might help you see what is supposed to be involved:
There are two O-rings involved, #104 and #107. In my case #107 was getting sliced by the sharp edge on the 45° bevel inside the fuel rail.
Old Sep 15, 2014 | 04:46 AM
blackozvet's Avatar
blackozvet
I had the same trouble a while ago with my 9th injector, tried 3 different o rings with no success, then tried a piece of fuel rubber tube i found in a box of carby bits, it worked great for the last few years,
Old Sep 15, 2014 | 06:51 PM
ghoastrider1
good tip black oz, thanks. Cliff, as always, you give great info, way over the top and I thank you.
Old Sep 16, 2014 | 12:13 AM
Cliff Harris
I learned at the school of hard knocks. A LOT of things have broken over the years since I bought my car in 1985. I'm a retired electronic engineer and I'm used to doing a lot of research, which comes in handy when I'm working on my car.
For example, you wouldn't believe how complex the AC system is (working on an upgrade to a Denso compressor -- article to follow). Here's a hint:
http://www.misterpeachy.com/VetteStu..._to_Denso.html
To 9th injector-- help
