Park/Neutral Safety Switch OR Backup Lamp Switch
Old Sep 15, 2014 | 12:34 PM
Stephenms's Avatar
Stephenms
Default Park/Neutral Safety Switch OR Backup Lamp Switch
I have a 1987 Vette and I've been trying to figure out why my reverse lights are not working and was at the conclusion it was the Park neutral safety switch. After some more research I found out there is also a backup lamp switch. So what exactly does the backup lamp switch do? I'm assuming it activates the reverse lights?
Could my issue still be the park switch? It starts fine in park and neutral. I'm curious which part I'd need to fix this issue. If it's both then so be it, though, finding the park switch has become a pain. None of the local auto part stores has them anymore, discontinued item.
Old Sep 15, 2014 | 02:03 PM
MrWillys's Avatar
MrWillys
You have a switch in your shifter that does 3 things. Neutral safety, backup lamps, and park neutral signal so ECM knows it's in park or neutral.
Old Sep 15, 2014 | 11:52 PM
Cliff Harris's Avatar
Cliff Harris
I had problems with my backup lights. They would work if the shifter was pushed forward in Reverse but not if the shifter was pulled rearward. The switch was out of adjustment and a little tweaking fixed it.
There are two screws that hold the switch assembly to the shifter, one in the front and one in the rear. There are slots so the switch can be moved to where it needs to be.
Old Sep 16, 2014 | 10:02 AM
Just BOB's Avatar
Just BOB
I believe I would start by checking the B/U lamp fuse. If it is good, I'd then check for good B/U bulbs. If both these check out OK, I'd then check for power at the B/U switch. If you have power to the switch, then jumper across the switch. If the lamps light then you have a bad switch or it is out of adjustment. If the lamps don't light then you have an open circuit going back to the lamps.
Old Apr 8, 2016 | 01:53 PM
Stephenms's Avatar
Stephenms
I can't believe it took me two years to respond to this. I guess it's something I had forgotten about!
My reverse lights were intermittent when I first got the car, now they don't work at all. Today I had my interior apart and remembered I had posted about this issue before. I redid the testing I did and came up with turn lights work, fuse receives power, the reverse lights do not come on when jumped, I adjusted and wiggled the neutral safety switch but to no avail. So now I'm stumped. I do have my electronic service manual and normal service manual so I'll consult those soon. Any ideas where to start? Neutral safety switch works how it's designed, for the most part, no crank in gears and solid crank in neutral and park.
Old Apr 8, 2016 | 02:28 PM
Hot Rod Roy's Avatar
Hot Rod Roy
Originally Posted by Stephenms
I can't believe it took me two years to respond to this. Any ideas where to start?
I'd recommend you start by reading MrWillys, Cliff Harris', and Just Bob's suggestions! They have been anxiously waiting to hear about the solution to your problem!
Are the light bulbs good? Do you have 12 v. on the green wire of your Park/Neutral/Reverse switch with ign. on and in reverse? Do you have a good ground connection at the sockets of the light bulbs? The white lights on the sides of your rear fenders should also come on when you're in reverse.
Two years?!
Old Apr 8, 2016 | 02:46 PM
Stephenms's Avatar
Stephenms
Two years?!
I did try their suggestions but came up empty. My next step is check grounds. And yes I'm aware all four lights should turn on when reverse is engaged. All light bulbs are good. I'll check the green wire at the switch while in reverse.
When I first got the car I cut out a keyless entry unit it had, think it could have been wired into the reverse lights? It wouldn't make too much sense but hey, you never know.
Old Apr 10, 2016 | 11:52 AM
Stephenms's Avatar
Stephenms
I fiddled around with this switch a bit more. I had the significant other check for lights while I removed the neutral safety switch. With the nuts off and the switch loose and gently moved the plastic rails back and forth and also twisting gently. No lights turned on what so ever. The only power in getting with key on is to the darkish blue wire.
Old Apr 10, 2016 | 12:03 PM
WVZR-1's Avatar
WVZR-1
Do you have the FSM for this car?
Old Apr 10, 2016 | 04:02 PM
Stephenms's Avatar
Stephenms
I do yes. I have yet to look through it, having trouble finding it lol. I'm not currently home but I think I know where I left it
Old Apr 10, 2016 | 04:40 PM
Hot Rod Roy
The dark blue wire is the power to the switch. If you can't get power to the light green wire, it's time for a new switch. Try a jumper from the dark blue wire to the light green wire on the switch (with key on). Lights?
Old Apr 10, 2016 | 04:47 PM
Stephenms's Avatar
Stephenms
Light green is what I was shooting for, I'll give that a try. Now I checked those wires WITHOUT the switch connected and got the same results.
I've been looking on the Internet for a park/neutral safety switch for automatic and am coming up empty. There is a used one on eBay for 40 bucks but the owner doesn't know if it still works. There's a "new" one on Corvette Mods but the description their giving is for a manual but the picture is an auto switch lol. Any ideas on where to get one of these things? I hear they rarely go bad. Just in case my switch is bad.
Old Apr 11, 2016 | 09:54 PM
Stephenms's Avatar
Stephenms
Blue to light green DID activate my reverse lights. So with that being said, I'm looking for a new neutral switch. I heard they're interchangeable with 86/87 camaro switches. They look promising but the mounting are different, I'd have to get hands on one and match up. I can't seem to find these switches anywhere. Or rebuild mine?
To Park/Neutral Safety Switch OR Backup Lamp Switch
