I ran in an auto cross today and did just fine. The car lost no oil and is clean and good why would the change oil light come on and how do I go about resetting it? Thanks
The "change oil" light comes on to let you know to change the oil.
There is no magic oil sensor that can test the oil.
The computer relies on whoever last changed the oil to reset it after every oil change.
If the oil life monitor is not reset, you will see the "change oil" light long before the next oil change is due.
Hard to believe you "overlooked" the sticky. If's directly below the "NEW THREAD button you needed to use to post this thread.
