Performance tips for '92 LT1
You could have a bad coolant temp sensor, stuck injector, bad O2 sensor, etc that is causing the car to run pig rich. Or you need to shift out of 2nd gear haha. Get an ALDL cable, scan software, and an old laptop and log it while you drive for awhile since you're tech-savvy.
Any thoughts on the services provided by that site. The testimonials sure sound good, but you know they will only post the best reviews and none of the bad ones. Basically, for those that don't feel like reading about it, they have give you logging software to use, you drive the car logging the data, email them the logged data, they set-up a tuning profile, email it to you, you load it in the PCM, drive the car and log data, send it to them, and so on, up to three tunes for $115, $35 any additional tunes. Personally, while I am tech-savvy, I am far from knowing what each setting does in the PCM programming. I think this would be a very good learning experience as I'm a hands-on learner. It would give me the opportunity to see the changes being made to the various settings, and experience what each change does first hand.
1.6:1 roller rockers
Long tube headers
rear end gears
Dyno Tune
http://home.insightbb.com/~nathan.pl...rformance.html
As for his claims on a "stock LT1", I have my doubts. Over 2 tenths, 3mph and 3-4 mpg???? I've never tried to extract optimal power and efficiency from a stock LT1. There are people on this forum that have. Maybe those claims are possible.
The best option for under 1000 is to change the roller rockers (my 2 cents). Good rollers and spring parts w/labor around 700 at a good shop. If you can do it yourself knock off half the price. I have another thread on here that I created asking for advice on the rockers. One of the members even provided a full part list with numbers. The mod adds around 15HP + or - on parts and engine shape.
good luck and if you do find an affordable upgrade please email me and let me know.
Now another question look at these two articles from Super Chevy and please help me out with this performance improvement question.
http://www.superchevy.com/how-to/vem...throttle-body/
http://www.superchevy.com/how-to/vem...injection.html
If I add the open box lid, the Mass air, and a 52mm TB. Will that become 18RWHP like they talk about?? What am I missing is it too good to be true?
such as long tube headers. The cam has to match also. You can get some gains with a cam but that still has it limitations with an otherwise stock engine.
So those modifications may provide some marginal gains but there are definitely not cumulative no matter what the magazine articles imply. Remember they're in business to make money - have to make the advertisers happy.
