Air hose was not on recently I will check stuff out tomorrow
Thanks Cliff
Steve
Didn't want to crank appears had a weak battery. Quick charge fires up. Checked MAF sensor cleaned it up. Would idle at 700 and after a few idled at 1400. Before clean MAF.
Checked for air leaks on Super Ram. leaks yes May be hose from Throttle body to valve covers or I may get to use my new Laser cut gaskets. New there was a reason I ordered 2 sets and was thing about buying two more sets. They sure were cheap.
Thank Scott for making the gaskets to the Super Ram
will be ordering more soon.
