84 4+3 noisy reverse
Old Sep 28, 2014 | 08:24 PM
Dano84's Avatar
Dano84
6th Gear
Default 84 4+3 noisy reverse
My 84 has the 4+3 transmission it works fine except when its in reverse. Reverse is very noisy it sounds like the '' whine '' that some smaller cars with manual trans makes except 20 times louder. Its loud enough that people near by will turn and look. 1st thru 4th are fine no noise at all. I changed the oil and the magnet was fairly clean. I bought the car this way so I don't know if it started suddenly or slowly. I need to know if there might be a in car repair or do I need to pull it and any info on manuals for these trannys would be great.
Old Sep 29, 2014 | 03:57 PM
frank j. moran's Avatar
frank j. moran
Sounds like it's in the 4 speed portion of the transmission, the reverse idler gear or bushing may be bad.? If the OD unit was ever taken apart it is very easy to dislodge the thrust washer that is in the 4 speed unit while reassembling the OD unit to the 4 speed. Take a look at some parts breakdown and you will see what I'm talking about.
Old Sep 29, 2014 | 04:38 PM
volkswagens-for-life's Avatar
Is it just the gear whine? It might just be normal... some cars are louder than others.
Old Sep 29, 2014 | 06:53 PM
Dano84's Avatar
Dano84
6th Gear
It's highly possible the OD was apart there is silicone on the mating surfaces. I will get it back on the lift as soon as I get the wife's car off of it. (She wrecked her daily driver and she thinks it's more important than my toy, go figure) Does anyone know where I can find a parts breakdown for the four speed and OD. I haven't been able to find much on the web.
Old Sep 29, 2014 | 07:55 PM
DanielRicany's Avatar
DanielRicany
I'm thinking the thrust bearing on the shaft that comes off of the OD front cover inside the transmission.
To 84 4+3 noisy reverse
