ZZ4 cam
Old Sep 29, 2014 | 10:26 PM
89C4TunePort's Avatar
89C4TunePort
Default ZZ4 cam
Have a question about the zz4 gm cam. I installed the cam in a Newly rebuilt motor. What I understand is that it is a hydronic cam but requires zero/zero lash on the rocker arms? Can someone help me confirm this? Thanks
Old Sep 30, 2014 | 12:13 AM
mcm95403's Avatar
mcm95403
Yes, that is correct. You should adjust it per factory specs.
What other mods do you have? I'm curious how you like it. I was torn between that cam and the LT-4 repro that I ended up with.
Old Sep 30, 2014 | 12:22 AM
JackDidley's Avatar
JackDidley
Zero + 3/4 turn.
Old Sep 30, 2014 | 06:34 AM
C409's Avatar
C409
..... Just Google : Valve adjustment , Hydronic cam .........
Old Sep 30, 2014 | 02:05 PM
ch@0s's Avatar
ch@0s
You will kill your cam if you don't do it right.
To ZZ4 cam
