Steering Column Question
Old Sep 30, 2014 | 05:50 PM
LannyL81's Avatar
LannyL81
Default Steering Column Question
I have the steering column disassembled like in the borrowed picture below (I have the turn signal switch pulled out a bit).
Is it normal for the shaft to be able to move freely up/down, left/right, in a circle or is there something wrong?
Also, has anyone replaced the clock spring? Curious as to how to get the clock spring electrical connector down the steering column without damaging it or the other wires in the column.
I was going to pull all the wires in the column up and then push them all back down, but one of the connectors is quite large and is never going to fit into the column.
Any help or hints will be greatly appreciated.
Old Sep 30, 2014 | 07:53 PM
WVZR-1's Avatar
WVZR-1
I separated the yellow shell from the 2 wire connector that is used tonight on a coil. No problem, simple release and then it should go down the column very easy. In this eBay offering you can see the white wire connector that is latched inside of the yellow shell. It should be very self explanatory, I used a small pocket knife because it was close. A very small blade screw driver (pocket type or miniature) would work better. The middle snapshot and use the "ZOOM".
http://www.ebay.com/itm/GM-Steering-Column-Clockspring-out-of-a-1997-Oldsmobile-Cutlass-Supreme-/171180790940?pt=Motors_Car_Truck_Parts_Accessories&hash=item27db2b949c&vxp=mtr
Old Oct 1, 2014 | 08:07 AM
LannyL81's Avatar
LannyL81
WVZR-1: yep....I saw in a diagram somewhere that the yellow shell is a separate piece so I have removed it from the connector on the broken clock spring...that is still in the car; used a precision screwdriver and came right off.
I was going to practice using the broken clock spring to see if it will go through the column before I try the replacement one.
I would like to know how someone replaces the turn signal switch. I have searched YouTube but have yet to see an actual video of the turn signal connector going through the steering column. Only way I can see is that the steering shaft would have to be removed.....not going to do that unless I have to.
To bad that the tiny connector on the backside of the clock spring does not come-off, would be really easy to pull that one up through the column.
Old Oct 1, 2014 | 09:27 AM
WVZR-1's Avatar
WVZR-1
Lots of room, you should have no issues fishing the harness down the column. The turn signal switch connector goes lengthwise up the column. You don't need to remove any shafts. Just be careful and don't disrupt the ignition switch rod and the dimmer rod. I don't recall the park-lock mechanism for an A4 creating issues either.
Old Oct 1, 2014 | 05:04 PM
LannyL81's Avatar
LannyL81
With a bit more disassembly; the metal panel that the lower trim panel screws to and also the column bracket and finally the plastic wire tray, I had no trouble getting the clock spring connector up or down the column.
Now I am just waiting for the replacement clock spring to arrive from the salvage yard I purchased it from; supposed to be here on Tues Oct 7th.
Also took the clock spring apart to see just what it was I broke; broke the ribbon wire at the connector, no way to repair.
Old Oct 2, 2014 | 06:22 PM
HlhnEast's Avatar
HlhnEast
When I fished a new turn signal assembly harness thru the column housing I taped the wide connector to the wires to keep it as narrow as possible and to cover all the possible hang up points. I am sure this will help with fishing any wires thru.
Good luck!
Old Oct 5, 2014 | 02:08 PM
LannyL81's Avatar
LannyL81
I was able to pull the SIR clock spring wire down the column with very little problem. Would not want to try to do the turn signal harness & connector though!
All done.
Old Oct 8, 2014 | 04:27 PM
C4vettrn's Avatar
C4vettrn
Something must be in the air! I broke the same thing. I took the plastic housing apart and pushed the wire ends back in. Then re-attached the cover and put a dab of glue over the plastic nubs I cut to remove the cover. It works fine, now I am having turn signal dimmer pieces issue
To Steering Column Question
