Disable Light Sensor Resistor Size?
Old Jul 30, 2002 | 10:37 PM
Fartsy95vert's Avatar
Fartsy95vert
Default Disable Light Sensor Resistor Size?
To disable my 95 daytime running lights I need a 100 ohm resistor conected in parallel with the light sensor, but what I need to know is what are the other spec's for the resistor? e.g. 1%, 5% and what voltage? :confused:
Old Jul 30, 2002 | 11:00 PM
konroh's Avatar
konroh
Default Re: Disable Light Sensor Resistor Size? (Fartsy95vert)
You should be able to use any 1/4 watt resistor...i just used one from radio shack and it worked fine...the precision really doesn't matter, just around 100 ohm...
:cheers:
