ASR/ABS codes
Old Oct 2, 2014 | 02:56 PM
scotth48's Avatar
scotth48
Default ASR/ABS codes
'93 was running well before turning on a/c. Engine stumbled, stalled would not start. Towed home. Checked ecm codes, only a 68 but that was because I disconnected connector from upper two wire ac clutch switch. Jumped a and g at first could not get to 9.0 but did an cleared in 9.7. Car would start but same condition as before. Shut engine off and take fob away and the car honks horn so have to disconnect battery. Dash lights dim at times, no lights for radio or in ac controls, even though heater fans run, cannot shut off. No power to operate windows, seats. Passive key light dimmer than others and goes off when you try ignition. Also I don't hear fuel pimp running when I try to start. Would like to get it back up and running before I store it in a few weeks.
