Driver's window wiggles back and forth, why?
Old Jul 31, 2002 | 12:34 AM
FlyboyZR1's Avatar
FlyboyZR1
Default Driver's window wiggles back and forth, why?
If I bring the drivers window half way down, I can literally wiggle the entire window back and forth, but it still goes up and down fine, and seals with the weatherstrip. Is the window on tracks or someting that can come loose? The passenger window won't do this.
Old Jul 31, 2002 | 02:02 AM
greg84's Avatar
greg84
Default Re: Driver's window wiggles back and forth, why? (FlyboyZR1)
hi,take your door panel off and on the top of the door resting against the glass are 2 felt bumpers.get a 10mm socket and try to adjust the bumpers to keep slight pressure on the glass.this should take care of your promblem.good luck greg84
