Less than 4 bars
Old Jul 31, 2002 | 12:50 AM
kabnvtt's Avatar
kabnvtt
Default Less than 4 bars
Hey all just trying to find out what the average was for fuel starvation under hard accelearion with less than 4 bars, is it common with all C4s?, or just L98s, has anyone found a fix for this other than running full?TIA :cheers:
Old Jul 31, 2002 | 01:19 AM
GlockLT4's Avatar
GlockLT4
Default Re: Less than 4 bars (kabnvtt)
As long as I have 3 bars, i'm usually ok. But after that i can feel it sometimes.
Old Jul 31, 2002 | 01:33 AM
bill mcdonald's Avatar
bill mcdonald
Default Re: Less than 4 bars (Glock'94)
Before I could floor it with 2 bars no problem. I never let my gas go below that...
After "something" happened, not sure what, it will now nose dive at 4 bars.
Old Jul 31, 2002 | 01:39 AM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
yup...your so correct on the four bar theory.....especially going at a stand still and turning the corner while acceleration.......something with the way the fuel tank was designed around the fuel pump.....I dunno....not to GM genious if you ask me.....
a $27000-$35000 car with fuel starvation problems fresh outta the factory.....fun huh.
Not sure on the fix either....
MINE does it.....its embarrassing when you have a passenger....so I make sure I have over a half a tank....
jeff :cool:
Old Jul 31, 2002 | 03:54 AM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Hmmm, was running at the track and had two bars left at the end of my last session. No starvation, was hitting the corners hard and 140 down the front straight.....different cars I guess
Old Jul 31, 2002 | 07:57 AM
RichS's Avatar
RichS
Default Re: Less than 4 bars (Jeffvette)
I have starvation problems at below a 1/4. Coming off turns in Pocono this year with a 1/4 tank I was running out of gas.
Old Jul 31, 2002 | 08:07 AM
ericcer's Avatar
ericcer
Default Re: Less than 4 bars (RichS)
4 bars for me.
Old Jul 31, 2002 | 08:14 AM
BBA's Avatar
BBA
I can go all the way to zero bars showing and still have no starvation in corners and under hard accelleration.
You know what causes starvation at low fuel levels right? It's a deteriorated sock on the end of the fuel pump suction in the tank. You can buy a replacement sock for less than [/i]$20.00[/i] from NAPA.
[Modified by BBA, 7:15 AM 7/31/2002]
Old Jul 31, 2002 | 11:05 AM
ZELLSLIFE's Avatar
ZELLSLIFE
Four bars only when turning left from a stand still.
Old Jul 31, 2002 | 11:08 AM
93TorchRedC4's Avatar
93TorchRedC4
I know 4 bars does it for me too. Hate having it happen with passengers too!:bb :seeya
Old Jul 31, 2002 | 12:24 PM
mayberry's Avatar
mayberry
Fuel starvation at 4 bars - heck yea, I run out of gas completely at 3 bars. I ran out the first week I had the car. Never let it get to 1/4 of a tank now.
Old Jul 31, 2002 | 12:58 PM
BBA's Avatar
BBA
In case you guys did not notice before....
It is EASY to FIX
Just put a new sock on the fule pump suction in the tank.
Old Jul 31, 2002 | 01:29 PM
C4-Wolf's Avatar
C4-Wolf
Default Re: Less than 4 bars (BBA)
I've never had a problem, but I've only been to the track a couple of times (I've never had a problem on the street). Also, I do have a new fuel pump with a new strainer sock. Coincidence?
Old Jul 31, 2002 | 03:07 PM
REW89's Avatar
REW89
Me too except it is more around 2-3 bars (convertible). Usually my computerized range monitor indicates I have aobut 60 miles left. Hit it hard and starvation occurs, expecially in a straigiht line. I just always put gas in when the range indicator says 100 miles. Yes, it should not happen but so far that is this only major eccentricity I have encountered and I can live with it.
Bob White
Old Jul 31, 2002 | 03:14 PM
CNTDRV55's Avatar
CNTDRV55
It is EASY to FIX
Noticed. Thx :yesnod:
[Modified by cgtarga1, 1:14 PM 7/31/2002]
Old Jul 31, 2002 | 05:21 PM
Bat Man's Avatar
Bat Man
4 bars = get your butt in the gas station
3 bars = putting to gas station
2 bars(reserve) = stuck on side of the road.
This is my car though, all C4's are different.
My 88 had 50 more miles with 1 bar left.
Old Jul 31, 2002 | 06:20 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Default Re: Less than 4 bars (Marty McFly)
It seems to me as if the fuel system wants x amount of weight in the tank or it gets upset with you. 2 bars and I better be pretty f***ing close to gas station. Last time I wasn't and ran out, I lost my fuel pump, had to be towed home. Got out the manual, paid $100 for a new pump (dealer) and found out it wasn't that bad of a job............ But looking at the pump assembly, float, tubing, etc, etc, on the way to pick up the pump I figured I'd be getting that entire assy, WRONGO BUCKO my price on that assy=$960.00........................... I think G.M. should put a gun to our heads and just call it what it is, theft.................... :cuss :cuss :cuss :cuss :cuss :cuss :cuss :nopity
To Less than 4 bars
Old Jul 31, 2002 | 08:45 PM
fixvet's Avatar
fixvet
Have a friend w/ an '86 that stuttered under 4bars of fuel. I told him he may have water in his tank and to buy some fuel additive that I used to use during the winter months back in the Midwest to help mix up the fuel with the water to burn it out. Can't remember which product he bought, but it sure fixed the engine stuttering with a low fuel tank. Could be a cheap fix for you.
Good luck,
Fix
Old Jul 31, 2002 | 08:52 PM
95wht6spd's Avatar
95wht6spd
Never had it happen. I run mine until the "check gauges" light comes on a lot too. My friend has a 96 and has never mentioned it either.
Old Jul 31, 2002 | 09:27 PM
kabnvtt's Avatar
kabnvtt
Default Re: Less than 4 bars (95wht6spd)
Thanks for all the replies. I have had the car for about 5 years and it has had the problem since day one. I have replaced everything, I do keep more than 4 bars for the most part, but since the fuel pump change,strainer,filter,fpr, this is the first time I have been below 4 bars. It seems to do it from a dead stop to full throttle. :cheers:
