Code 34?
Old Jul 31, 2002 | 01:43 AM
your drinking buddy's Avatar
your drinking buddy
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Default Code 34?
I lost my Haynes to see what it is. My car set this today. What is it?
Old Jul 31, 2002 | 01:49 AM
purple jinx's Avatar
purple jinx
Default Re: Code 34? (vettes rule)
http://www.c4vettes.com then click on In Depth Info, then ECM Codes. :cheers:
Old Jul 31, 2002 | 01:51 AM
your drinking buddy
Cruise-In V Veteran
Thanks :cheers:
Old Jul 31, 2002 | 02:08 AM
vader86's Avatar
vader86
its a MAF code, replace relays then the MAF if it comes back
Old Jul 31, 2002 | 11:31 PM
your drinking buddy
Cruise-In V Veteran
Default Re: Code 34? (vader86)
Heres a problem, my car is speed density (91). I dont have a MAF.
Old Aug 1, 2002 | 01:32 AM
vader86's Avatar
vader86
oops, then it would be the MAP code
Old Aug 1, 2002 | 10:55 AM
dlmeyers's Avatar
dlmeyers
Code 34 on a speed density system is signal voltage too low. The computer said the sensor is returning a voltage too low for what is going on. If this code continues to set, the computer will substitute a fixed value and use the Throttle Posisition Sensor for determining fuel delivery from mapping tables etc. May not even notice the default value. Check the connections, probably the sensor. Good luck.
dlmeyers 90 coupe zf6 3 speed shocks
To Code 34?
