1984 help
Old Oct 4, 2014 | 11:13 PM
doug53098's Avatar
doug53098
3rd Gear
Default 1984 help
I have 24,000 miles on my 84 Vette and I brought it to the local dealer for oil change. While there I had them change the spark plugs, and when I went to pick it up they said to run a tank of fresh gas thru it. I left andd went to pull out on the highway and I step on the gas and there was very little response. I pulled into the gas station and put in 14 gallons of 91 octane to see if that would help. I took it to a industrial park and every time I would step on it it felt like it was bogging down and if I let off the gas it would accelerate and if I pushed down the peddle more it would not matter. After bringing it back to the dealer and told them what happened they said they would look at it. That was on Tuesday and they still have not fixed it, what could they have done to cause this? Thanks for your help!
Old Oct 5, 2014 | 03:40 PM
wilcar's Avatar
wilcar
Could be a fuel problem. Check fuel pressure and replace fuel filter. Should be 15 psi , if not then you probably need a new pump or at least a new sock. You might consider getting it out of the stealership and to a competent corvette friendly mechanic, who knows what they screwed up and they will just start guessing and replacing parts.
Old Oct 7, 2014 | 04:16 PM
doug53098's Avatar
doug53098
3rd Gear
When I was park and stepped on the gas it would respond with no problem.
Old Oct 7, 2014 | 04:34 PM
corvettenorway's Avatar
corvettenorway
wrong gap on plugs , and yes fuel pressure / filter . air box flaps
Old Oct 8, 2014 | 11:12 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Only thing they could have screwed up that would matter much is the plug wire routing which would cause a misfire/rough running.
X3 on the recommendation to check fuel pressure under load.
Engine revs up in park/neutral b/c there is no load on it; fuel/air requirements are much less than in gear, to raise RPM.
To 1984 help
