Flat washer on rear spindle?
Old Jul 31, 2002 | 05:31 AM
BlackRocket's Avatar
BlackRocket
Default Flat washer on rear spindle?
On disassembly of my rear bearings I noticed a paper-thin flat washer between the bearing and the lower part of the spindle. (Right before the ABS cog). One bearing assembly had this washer installed and the other side had none. Do I need this washer to re-install my bearings/spindles or are they really necessary? Anyone with knowledge of this please reply...
[Modified by BlackRocket, 3:32 AM 7/31/2002]
Old Jul 31, 2002 | 09:35 AM
boxerdog's Avatar
boxerdog
Default Re: Flat washer on rear spindle? (BlackRocket)
I just did this last month. Yes, you should have them on both sides. They are also shown in the Haynes book. Sounds like your missing one.
Old Jul 31, 2002 | 09:52 AM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
seems like you should have them on both sides. Funny you mention this, on my '85 I was missing one on the drivers side when I replaced my rear bearings...... I haven't done the '90.... yet.
Old Jul 31, 2002 | 02:07 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
I reused mine and I think they are more of an Oil/grease seal for the bearing then a typical washer.Dont these bearings sling out grease when they age?
I could be wrong.
Also,its not the first time Ive heard of one side having one,and another missing.Maybe some warranty work or something in the past,the tech forgot to reinstall it or they forgot on the assembly line.
Old Jul 31, 2002 | 11:07 PM
JasonL's Avatar
JasonL
Default Re: Flat washer on rear spindle? (Bill's86Coupe)
The Helms says to replace them when you replace the bearings. It's called a spindle washer or something like that...
Not sure how critical it really is, though.
To Flat washer on rear spindle?
