Steering column bearing
Old Oct 5, 2014 | 11:19 AM
occupa's Avatar
occupa
Default Steering column bearing
Where can I locate this bearing? 1984 automatic.
Tilt and telescopic steering column
Thanks for your help
Old Oct 5, 2014 | 02:35 PM
WVZR-1's Avatar
WVZR-1
Giving you this information for only the image. Those bearings have only ever been serviced in the package that this link displays. There may be some after-market vendors with but I doubt it. Very seldom do technicians use the entire package so if you know a GM tech somewhere they would be in his box. The package from GM is 7844651 and will be on all dealers shelves for sure.
http://www.rmsautoparts.com/proddetail.php?prod=7844651
Maybe eBay if you're looking to save money! Use the GM # to search. I didn't.
If you actually need the seat #13 that used to be available with a spring kit that isn't available any more so you'll need a used part there. Every Saginaw tilt column through the mid-late 90's used the same parts. I probably have the bearings in a complete housing but I'd have to look and see if I have the seat #13. I could. Where are you located?
Old Oct 6, 2014 | 09:58 AM
occupa's Avatar
occupa
Thanks for the information.
The associated parts are still good, just the upper bearing let go.
I am in Dayton, Ohio.
and some information I have found mentions that the upper seat, race inner (13) above is pressed on the shaft. Mine is not... just slides up and down.
Does this make sense?
Old Oct 6, 2014 | 10:15 AM
WVZR-1's Avatar
WVZR-1
The #13 is NOT pressed, there are no pressed parts onto the shaft. The bearing that you have in your snapshot is pressed into the housing. If you know a GM technician in a shop or maybe even any independent shop they might have the bearing in their tool box or with spares. There should be no need to buy the kit BUT if you do buy the kit use all of it.
The FSM should cover the install but will of course mention the use of a special tool. It would be good if you could. If you know a GM technician I believe the correct J-tool is a J-38369 and a J-8092 driver. I've used a large socket mounted "backwards" onto a 1/2" extension so you can use the large flat face of the socket.
Old Oct 9, 2014 | 10:49 AM
occupa's Avatar
occupa
Great information and thanks
and some more
5696210 was the part number for the bearing now Obsolete.
26001827 is now the part number for the bearing $57.00 ea.
However 7844651 is the number for the kit with 2 bearings and the other items at $67.00.
I opted for the kit and will change all part with the new stuff.
Hope to have it back together this weekend.
Old Oct 10, 2014 | 09:55 AM
occupa's Avatar
occupa
Using a 1/8 punch and the notches in the housing, I removed the old retainers
I could not used the flat side of the socket as the plastic carrier was taller that the steel retainer. So I just tapped it home using a punch and stepped around the ring to keep it square.
I retrieved 13 ***** from the damaged bearing and I think the 14th is further down the column. So I am going to proceed further down before putting it back together.
Old Oct 18, 2014 | 09:33 AM
occupa's Avatar
occupa
I put the clip on upside down and the will not allow the insulator to seat properly.
The open end of the "horseshoe" goes to the two brass contacts
I used a 5/16-18 set screw to lock the telescope shaft.
Otherwise the lock plate compression tool only pulls on the shaft instead of compressing the spring.
All back together.
Only two people take apart a watch.
A watchmaker
and
An Idiot
To Steering column bearing
