help on fx3 install
I just got my shocks back from delta vee.
the right rear keeps showing error code 22.
I switched actuators with right front and still get code 22.
are the actuators the same front and rear.
Is there something wrong with the shock?
thanks for your help,
Mark
If the Selective Ride Control module senses that if that actuator is not moving, moving too slowly, or not receiving the feedback signal, a Code 22 is set.
There are diagnostic procedures in the FSM to test the actuator.
With the key off, remove the actuator from the shock. Have somebody turn the key to ON and check to see if the actuator gear moves. Does it?
