Has anyone tried to run a higher fuel pressure , around 55psi and tune the open loop Wot mixture leaner to take advantage of better fuel atomization? If so how can the leaner mixture be accomplished ? thru the AFR x10 open loop table or the % change to Fuel/Air ratio vs temp & rpm tables or both? 1994 LT1 have tunercat and am dangerous!
Re: Higher fuel pressure and leaner mixture (RonD)
[QUOTE]Has anyone tried to run a higher fuel pressure , around 55psi and tune the open loop Wot mixture leaner to take advantage of better fuel atomization? If so how can the leaner mixture be accomplished ? thru the AFR x10 open loop table or the % change to Fuel/Air ratio vs temp & rpm tables or both? 1994 LT1 have tunercat and am dangerous!
:confused: :crazy:
Actually wot is not "open loop", it's "power enrich mode". So don't use the open loop tables!
Just use %change to f/a vs rpm.
And yes a lot of folk turn up the fp and then retune the wot-but you'll need to retune your ve tables for part throttle also-or try just changing the fuel inj. constant first to bring it back in line.
Oh yea....welcome to the forum!!
