Cruise module vacuum routing
Old Oct 23, 2014 | 10:50 PM
Hairy W Bush's Avatar
Hairy W Bush
Default Cruise module vacuum routing
I have 1 hose connected and the other disconnected...wondering where it's supposed to go because I can't find info on this anywhere. It's the one on the bottom. I attached a pic just in case.
Old Oct 24, 2014 | 01:11 AM
Heysailor's Avatar
Heysailor
Two vacuum lines from the cervo ... larger dia. of two ,#6 in the diagrams, goes through the firewall to the brake/clutch switch assem.
smaller dia., #15 in the diagrams, goes to a vacuum T connection. This hose is only about 15'-18' long.
getting the larger dia. line , #6, through the firewall is a PITA... PM me if you need the advice on this hose.
Old Oct 25, 2014 | 07:52 PM
Hairy W Bush
ok something is hooked up to that already so there's something wrong. I believe it is the vacuum hose for the vented optispark. Where is that supposed to go? Here's what it is if you need a picture.
now with this hooked up wrong, I believe that's actually a vacuum leak.
Old Dec 31, 2021 | 07:49 PM
rancho deluxe's Avatar
rancho deluxe
6th Gear
Default cruise control vacuum line (to Brake cutoff)
Mine is rotted and split-broken at the servo. How long is the line? What diameter for replacement tubing? How to mount it thru the firewall? Any advice greatly appreciated!!! Thanks, Rancho
To Cruise module vacuum routing
