Flasher?
Old Aug 1, 2002 | 02:42 PM
lite blue's Avatar
lite blue
St. Jude Donor '12
Default Flasher?
Where is the turn signal flasher located in an '85? I've looked under and behind the dash with no luck.
Thanks. :D
Old Aug 1, 2002 | 03:13 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Default Re: Flasher? (lite blue)
Come on, did you really look behind the dash?
Old Aug 1, 2002 | 03:57 PM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
I'm not 100% positive but I think I saw the one on my 87 in the area of the ECM when I was pulling the chip.
Old Aug 1, 2002 | 04:21 PM
88BigGuy's Avatar
88BigGuy
Default Re: Flasher? (War Machine)
If it is in the same place as the 88 you might want to hire a :troll to get their hand up there. I can palm a regulation size B-Ball and crap I had a hard time changing mine. I had to get the wife :crazy: to change mine.
It is on the Pass side, close to the hump, not sure how to explaine. Mine would still make noise, so fortiantly I was able to listen for it to hunt it down.
Just keep looking, it is there, I would make sure you get a high output one. I had to change mine three times in one year. Have not had to change the HO one for a full year now.
Good luck
To Flasher?
