I've seen this topic around here but I can't find
anything right now.
Yesterday I got INFL REST light while driving and now I can't get
rid of it.
Does anyone know how to fix this problem?
(I've tried Diagnostic mode and there are no error codes)
The trouble codes are from the SIR system and don't show up on the regular ECM scanners. The Tech Section guide will show you how to ground the ECM pin to get the codes to flash the Infl Rest light. Most likely, it will be the right side sensor ground. The condensation from AC will eventually corrode the sensor connection and cause the failure. This has happened to both my 90s and I was able to fix them myself.
I got the Lights but no codes went ahead and cleaned both sensor (very dirty) and did the rest code thing (a bunch of times) but still have the lights is there another way to rest set the light. Also the battery was dead for about two weeks and that did reset it either.
