Pulling #36 Fuse (Interior Courtesy Lights)
I have tried with new door pin switches. They seem to break easily. When i hit a bump the interiors come on as does the "door ajar" light on the dash. This is very annoying and hazardous at night.
Has anyone pulled the #36 fuse? Before doing so i want to ensure that this is strictly for the interiors and nothing else.
Thanks!!
https://www.ecklerscorvette.com/corv...1984-1996.html
It may handle the power antenna too, but I don't remember
Thanks!!
- the interiors have gone off
- the cluster lights have gone off
- the radio has gone off
Now when i opened my door with the "door ajar" issue. The replacement switch (PART 20196) is located where the door meets the frame of the car when closing. I was messing around with the door and the door ajar kept coming on and off when i would open the door all the way and close it half way (without it even touching the door pin)
suggestions to fix? Pulling the fuse was a fix only for the time being. I do not wan to go without the radio or the cluster lights.
Thanks!
Thanks!
Thanks!
Good Luck!
