Get every FX3 trouble code
Old Aug 1, 2002 | 10:45 PM
enhance's Avatar
enhance
Default Get every FX3 trouble code
Well almost.
I get:
14
21
31
33
43
My left front VSS was disconnected so that probably caused these codes. I also tried to clear the codes by grounding the C for 2 seconds 3 times, but the codes are always there. How can I tell if I actually cleared the codes at all.
Am I supposed to do the grounding with the ignition on or off?
Any other ideas or fixes?
See http://forums.corvetteforum.com/zerothread?id=351477 for why it happend.
[Modified by enhance, 7:40 PM 8/1/2002]
Old Aug 2, 2002 | 12:35 AM
Jimwood's Avatar
Jimwood
Default Re: Get every FX3 trouble code (enhance)
Forget about trying to clear the codes. If the car is started three times and the wheels dont move the codes automatically turn on. Drive your car. Let it sit, no engine, turn it back on drive it. Turn it back on then you will be able to determine whats wrong.
As soon as you turn on the engine the computer does a self diagnostic.
The GM guys did the same thing, call me up,
Gm: dude your service engine and ride control lights are on now.
Me: They werent on when I you got the car, did you try moving it?
Gm: These guys are trained techs of course they know what they are doing (also inferred I was lying)
Me: Okay, see what it is.
Gm: [4 hours later] All the codes are off I guess your car just needed to be moved. No charge.
Try it out.
Old Aug 2, 2002 | 01:21 AM
enhance's Avatar
enhance
Default Re: Get every FX3 trouble code (Jimwood)
ok, I drove it around and the light went out like 10 feet from my garage. I drove it a little while and parked it.
Then I get back in and drive it again, the light comes back on and stays on. I'll pull the codes again tomorrow to see whats up this time. Thanks.
Old Aug 2, 2002 | 01:52 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
I'll send you an email with all the info you need.
Old Aug 3, 2002 | 06:16 PM
enhance's Avatar
enhance
Default Re: Get every FX3 trouble code (Jeffvette)
Thanks jeffvette.
The light suddenly went out after driving it for a little while and the system seems to be fine.
:cheers:
To Get every FX3 trouble code
