Random Whine from the 95.
Old Nov 3, 2014 | 08:35 PM
BucfanTitan's Avatar
BucfanTitan
Default Random Whine from the 95.
Ok here is the situation I have been hearing from the car that the mechanic can not hear.
From time to time I hear a whine coming from the driver side near the center heading back to the read end. It is the loudest when in reverse and you give it a little gas to go back. From there I notice it when coasting to a stop and barely tapping the brakes. also from time to time when starting out when the engine is cold, soon as it shifts it stops and I never hear it again when moving forward.
If the sound does start when coasting to a stop if I hit the brakes hard it stops and I will not hear the sound again for the duration of my trip.
My car is an auto, 95, 3.07 gears, & 29,500 miles.
I hope this makes sense to everyone.
Old Nov 3, 2014 | 10:24 PM
C409's Avatar
C409
..... Check the gear lube level in the diff ... and while you're under there ... check for fore and aft movement in the driveshaft/pinion yoke ... sounds to me like slightly loose pinion bearings ... or a possible wheel bearing on the way out ..........
