Knock sensor flush
Question for the OP, are you going to do a flush now? Mine is still sitting empty and will be doing flush shortly. What type of flush do you? I will be flushing, then draining they system again by pulling the KS out and then refilling with 50/50 green coolant.
Cheers.
squirt water from the garden hose into the block several times. It takes more than just gravity flow to remove the sediment. Once
the water looks relatively clean flowing from the knock sensor hole, replace the sensor, fill the system, run the engine until the tstat
opens, then open the pet-**** at the bottom of the radiator and drain. You are just draining the radiator, but by repeating the process,
the water-flush is cycling through the engine. There is a flush solution available....check it out.
Repeat the fill-and-drain operation several times until the water looks clear. Fill with coolant......
Cheers.
j/k.
i assume i fill rad, screw in the water to block, start car, ipen rad drain, and let it go into block as it comes out rad, then when water is clear out of rad, pull water from block, reinstall ks, shut rad drain, empty reservoir, fill rad with 50/50 , fill reservoir with 50/50, turn on car (block will be devoid of anything at this point?) watch for system to draw down the reservoir level as tstat opens, fill reservoir with more 50/50 as needed until the level stabilizes at warm level marking on reservoir tank?? is that right? And do i need to do anything for burping or will that method be allright?
going to fill my 85 block this saturday. been empty for a while after gettin drenched by brown sludge from ks removal.
j/k.
Sounds confusing to me. You have the fill procedure right, IMO.
For the flush, the goal is to run fresh water through the entire system, until all the old coolant and any contamination is out.
One way is to drain, fill w/water, run, repeat until the water is clean. Then drain and fill w/coolant mix.
The other way is to flush w/a hose....car not running. My recommendation for this was to plug your garden hose into your heater hose, which will push water though the heater core, water pump, heads/block and out the knock sensor holes. It gets every part of the cooling system and can be done in one operation rather than multiple fills/drains. When you shut the water off, the car drains though the knock sensor holes. Then fill w/coolant mix.
Either way works just as well. If you're using a garden hose, car doesn't need to be running. If you're using the fill 'n drain, you want to run it to mix it up in there, then drain.
[IMG
Usually, HD has all but one or two of what I need.
