1985 4+3 overdive drips
in july, i purchased a bone stock, all original 1985 4+3 with 28,000 miles on it. beautiful vehicle, perfect. you would be arrogant to ask for a vehicle in better condition. i flew to were it was and drove it home. from seattle back to dallas.
naturally, this was and still is a garage kept vehicle.
couple weeks ago i saw a couple red fluid drips under the car. so i lifted vehicle and checked the overdrive pan bolts. they were not very tight, at all. so i snugged them up. then the leaking really began. so satur-day, i lifted the vehicle and changed the overdrive fluid, essentially to replace the pan gasket. i had already read on this site what to do and how to do it and followed those directions. when i was done i went on a 30 minute test drive (using OD some and not using OD some). satur-day night, no leaks/no drips - sun-day morning no leaks/no drips. sun-day night not so lucky - drip, drip. oh, i am so annoyed.
o.k. so that's where i am. right now. mon-day. i have done nothing further.
what is my next step? thank y'all in advance for your time and wisdom.
steve
steve
Remove the pan and completely clean any old gasket material from the pan rail and from the mounting flange of the OD unit. Use a straight edge to check the pan rails for being flat. Straighten the rails using a flat bar and a small hammer. Check around the bolt holes to make sure there are no cracks or raised/depressed areas. Make sure the surfaces are clean and dry.
Once all that is done, apply a 1/8" bead of a good black RTV sealant on the pan rails making sure to circle the bolt holes. Install the pan while the RTV is still wet. "The Right Stuff" is a good RTV sealant as is the MoPar RTV sealant (get it from any Dodge/Chrysler dealership parts counter). Make sure to tighten the bolts in a pattern; tighten the bolts to 6-8 ft-lbs.
I have never seen any reason to wait for the RTV stuff to dry before fluids are added. At our shop, the techs will install things oil pans or valve covers using RTV, tighten them down and start an engine within 10-15 minutes. No leaks.
steve
no i am an not sure about the rear seal. i need to get the vehicle in the air so i can stand under it and really inspect it. this crawling under it on ramps and jack stand is for the birds.
thanks for the reply.
thank you for your reply.
anyway, i was trying to find out a "flow-chart" type order of possible eliminations of the problem. i figured the pan gasket would be the easiest solution so that's why i started with that.
steve
Completely. Use "The Right Stuff" sealant each time. You'll never have it drip again.
turns out the tranny/od case cracked and was seeping fluid when i drove it. the case was common to find the transmission shop said
thanks
matt
