Broke smog pump shaft
Old Nov 14, 2014 | 04:38 PM
agillings's Avatar
agillings
Default Broke smog pump shaft
Just finished up restoring my 85 . Took it on its 2nd test run and bang I heard something under the hood let loose. Pulled over raised the hood and there it was the air pump pulley laying in front of the engine belt no where to be found.
This was a brand new pump from Corvette America! It did a job on the alternator and water pump pulley. Called tow truck brought it home
The shaft right behind the pulley just broke. Does anyone have any idea what might cause this, Pump was not seized and pulley was not wobbling prior to shaft breaking
Old Nov 14, 2014 | 07:36 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Was the serp new and the tension within limits??
Are any of the other pullleys seized up?
After investigation it's time to contact CA, IMO.
Old Nov 15, 2014 | 10:09 AM
agillings's Avatar
agillings
Yes new tensioner new belt, nothing jammed. I contacted CA yesterday and they are sending a replacement since it was a new pump. Its is strange, after looking at the pump it was not a broken shaft. I appears that the front rotating assembly is pressed on the shaft. I looks like the press fitting let loose. I will post pic. Thanks Art
Old Nov 16, 2014 | 05:20 PM
1rstvert's Avatar
1rstvert
I have a 35000 mile GM factory 1990 L98 pump & brackets, pulley, hoses etc I would sell cheap with new Dayco belt PM me if interested.....
GM Factory is way better quality than China or Mexico replacement..IMO
To Broke smog pump shaft
