Faulty fuel pump?
Old Nov 14, 2014 | 06:39 PM
Tommycourt's Avatar
Tommycourt
Default Faulty fuel pump?
Went to the Goodguys today and hit heavy traffic on the way home. For about 10-15 miles we were at a standstill: 5mph to 25mph and until I hit the 202 East I could run up to 65-70mph. Parked in the garage and when I shut the car off it sounded like "sloughing" in the rear of my 88 verte.
It lasts found about 5-7 seconds and then shuts off. I started it up again and it made the same noise. No hesitation when idling nor no miss or sporadic problems on the way home. Does this sound like a fuel pump is going out? Problem is I can raise the car but can't crawl underneath to check the filter. My back is shot! Any and all suggestions advised will be appreciated!
Tommy
Old Nov 14, 2014 | 07:53 PM
Tommycourt's Avatar
Tommycourt
Default Re: faulty fuel pump
My 88 verte has been shut off for about an hour now and I went out and started it up again and it sounds noisy for about 5 seconds. When I shut the car off, it sounds as if the fuel pump is still pumping fuel through the fuel line.
Tommy
Old Nov 14, 2014 | 08:47 PM
l98tpi's Avatar
l98tpi
Max G’s
I don't think the fuel pump will stay running with the ignition switch off. You could do a pressure test but if you cant get under the car, it would be difficult to lean over and hook up the pressure guage too. Maybe you should take it to a reputable shop in your area if you have concern.
Old Nov 14, 2014 | 08:59 PM
leesvet's Avatar
leesvet
tried the gas cap?
the pump does NOT run after the key is OFF.
the tank CAN build pressure or a vac that tries to vent thru the gas cap. Next time, see if loosening the cap changes anything...you may need to look at the vapor recovery system and the cap.
Old Nov 14, 2014 | 10:29 PM
Tommycourt's Avatar
Tommycourt
Originally Posted by leesvet
tried the gas cap?
I tried it with the gas cap off. You can hear the noise, which I believe is the fuel pump when you turn the key and the car starts up fine. It will run w/o a miss and then when I shut it off it still runs for about 5 seconds before it quits. I actually sounds like the pump is still running trying to fill the fuel lines. One thing I did do was to put regular gas in it today, could that possibly have ANYTHING to do with that? I have run regular before however rarely and have never had anything like this happen.
Tommy
Old Nov 14, 2014 | 10:44 PM
jv9999's Avatar
jv9999
Fuel pump relay might be sticking.
Old Nov 15, 2014 | 12:54 AM
Cliff Harris's Avatar
Cliff Harris
Sounds like the oil pressure switch is still seeing enough pressure (or it's bad) to keep the fuel pump running after shutting off the ignition.
The fuel pump relay should open immediately when the ignition is shut off. That cuts off power to the distributor and the ECM will shut off the fuel pump relay when it no longer sees DRPs (Distributor Reference Pulses), which come from the ignition module inside the distributor.
Old Nov 15, 2014 | 01:09 AM
Tommycourt's Avatar
Tommycourt
Cliff,
I will try changing out the oil pressure switch as it has been acting a little goofy anyway since my return from Ca. Will give it a try and see what happens. Thanks for your help!!!
Tommy
To Faulty fuel pump?
