more power for a C4
Old Nov 16, 2014 | 05:33 PM
j4royer8's Avatar
j4royer8
2nd Gear
Default more power for a C4
Looking for info on simplest and least costly ways to power up my '94 LT1 automatic. Nitrous? Cam/lifters? supercharger? headers/cat back? At just 50k miles it still runs strong but.........
Old Nov 17, 2014 | 12:06 AM
ANTI VENOM's Avatar
ANTI VENOM
Simplest and least costly? For an initial investment, I will say Nitrous all day long.
Old Nov 18, 2014 | 12:18 AM
illenema's Avatar
illenema
Well this isn't the simplest but still worth your consideration
http://www.advancedinduction.com/LTX...adsCamKits.php
Old Nov 18, 2014 | 05:54 AM
Svante's Avatar
Svante
A low budget turbo setup
With a proper tune, you will have the power everytime and you dont need to worry about running out of nitrous!
/Svante.
Old Nov 21, 2014 | 09:43 PM
j4royer8's Avatar
j4royer8
2nd Gear
Thank you gentlemen! My initial thought was nitrous, but the other suggestions seem well worth researching.
Thanks again,
John
Old Nov 24, 2014 | 06:49 PM
gerardvg's Avatar
gerardvg
Nitrous Oxide is a sweet sensation, however the more you use it the more you have to pay. Is it legal on the highway in the United States?
I know here in Australia, you will be busted with a nitrous system unless the bottle is disconnected. (stupid more dangerous if the valve is not closed tightly)
Is a great idea for the occasional use but if you are addicted to more power all the time a Turbo or supercharger setup gives you smooth idle, drivabillity and performance.
C4 ZR1 performance
However a engine rebuild with miniram inlet manifold, performance camshaft afr heads and long tube headers may be a little cheaper.
Old Nov 25, 2014 | 10:00 PM
turbocvette's Avatar
turbocvette
nitrous is cheaper by far!!! even vs a turbo. People forget that turbos go bad as well especially a budget turbo. Prob piece together a kit or buy a complete kit ready to run for $500 or less. I think a turbo minimum on a fuel injected car would be 2k-3k with a tune and the cheapest parts that break more often than not. However using both for years now turbo is the most fun but its hard on parts there are usually bugs that need tweeking on a regular basis with budget builds etc. And also consider turbos do go bad if its an ebay turbo plan on 1-2 yrs use if your lucky. I also had a turboknetics go bad after 4 months of use luckily they repaired it for free and I sold it when they did and purchased a low buck ebay turbo this is still kickin today in a mustang I built 3 yrs ago. Both are fun and addicting. a $500 turbo could fill a nitrous bottle a lot of times!!
To more power for a C4
