R-D Camber Brace installed!!!
Old Aug 2, 2002 | 10:24 PM
95AquaC4's Avatar
95AquaC4
Default R-D Camber Brace installed!!!
Sorta "fell" into place! Placed it through the passenger side. Nice fit, nice finish, and nice feel!! Disconnected some wires to get them out of the way, and removed the driver side fender panel to replace the bolt. Everything was a breeze. Well sorta, I did struggle with the pass. side bolt for a while before realizing that removing that panel would help. :yesnod: Thanks Dave!!! :D
Old Aug 2, 2002 | 11:08 PM
Tx07BlackZ51's Avatar
Tx07BlackZ51
Default Re: R-D Camber Brace installed!!! (95AquaC4)
:cheers: :cheers:
Old Aug 2, 2002 | 11:25 PM
4GTWRK's Avatar
4GTWRK
Your the second person this week to install the brace from the passenger's side. I guess I'd better give it a try, I may need to re-write my instructions.
Thanks for the feedbak!
Dave
Our new slogan "Feel the Difference", on t-shirts everywhere soon. :yesnod:
Old Aug 3, 2002 | 03:07 AM
BryanC's Avatar
BryanC
Default Re: R-D Camber Brace installed!!! (84c4)
The biggest problem I had was getting out the driver's side bolt. It would run into the power steering pulley before getting it all the way out. With the camber brace in place it was worse because the bolt has to come out further. I had to unbolt the power steering pump to get the bolt in. Then it's a royal PIA to remount the PS pump because the camber brace is in the way. This was on a 95 LT1 car.
Old Aug 3, 2002 | 09:26 AM
chucks88's Avatar
chucks88
Default Re: R-D Camber Brace installed!!! (BryanC)
My biggest problem was finding something else to do during the 4 hours I alloted to do the job. I had 3 hours to spare. :yesnod:
Old Aug 3, 2002 | 09:49 AM
95AquaC4's Avatar
95AquaC4
Yeah, it was rather simple to put in. I slid it through the passenger side from up top, not through the fender well. With the tabs pointed upward I fed it through until it was about 3/4 of the way there, then started to rotate it until the tabs faced the right direction and then it kinda just dropped into place. I left the wrapping that you put on it on. I cut it off afterwards. Saved on any scratches!! Thanks again.
Old Aug 3, 2002 | 12:31 PM
STL94LT1's Avatar
STL94LT1
Welcome to the "camber-brace" club.
Old Aug 3, 2002 | 12:55 PM
The Example's Avatar
The Example
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: R-D Camber Brace installed!!! (STL94LT1)
Hmmm, I may try that. I sat down for an hour so and tried to do it, but I ended up bashing my drivers door into a toolchest. $350. :(
I may give the camber brace install another shot when I feel up to it. For now it sits in the garage wrapped in tape and an old sock.
Old Aug 3, 2002 | 01:00 PM
silver & red CE's Avatar
silver & red CE
Default Re: R-D Camber Brace installed!!! (stormy652)
If you need some help,let me know, I'm in Palatine.
danstrom@voyager.net
Eric
Old Aug 4, 2002 | 11:40 AM
Darrell G's Avatar
Darrell G
I read somewhere someone talking about not having to jack the car up. Is that possible? Also what about removing the belt. Necessary also? I have an '89, L98. I don't have a floor jack or stands. If you do have to use stands, where to you put them? Does the suspension have to be in the extended position? It's kind of scary when you start trying to get get a mostly fiberglass car up in the air.
Old Aug 4, 2002 | 03:27 PM
4GTWRK's Avatar
4GTWRK
Default Re: R-D Camber Brace installed!!! (Darrell G)
Darrell,
Jacking up the car allows you to use a socket on the control arm nuts. You can do it with a wrench without jacking up the car and install the L-98 brace per the instructions.
Dave :seeya
Old Aug 4, 2002 | 03:41 PM
morphious's Avatar
morphious
Tell me what you think of it because I am thinking of getting one for my Vette. :cheers:
Old Aug 4, 2002 | 03:51 PM
FX GS's Avatar
FX GS
Default Re: R-D Camber Brace installed!!! (morphious)
The General should call Dave at R & D. As they say in the commercial:
"Don't leave home without it"
Old Aug 4, 2002 | 09:49 PM
STL94LT1's Avatar
STL94LT1
Stop thinking about it and just buy one. It will be the best bang for the buck, you can do for your Vette.
Old Aug 4, 2002 | 11:33 PM
GS 163's Avatar
GS 163
:cheers:
Old Aug 4, 2002 | 11:52 PM
J.R.'s Avatar
J.R.
Don't leave home without one.
45 min install - including jacking car and wheel removal.
Installed from passenger's side.
One of most cost effective handling options available.
Track handling after was more than noticeable.
Another satisfied customer, Dave.
18carfan's Avatar
18carfan
You know I have to have one of these shirts right Dave!!? :yesnod:
All of Dave's products are great! I have the cross-bar, camber brace, and truss bar and every one of them has made a difference. You couldn't ask for a nicer guy to deal with either. Do yourself a favor and call Dave sometime. You'll be glad you did! -Jeff
To R-D Camber Brace installed!!!
Old Aug 5, 2002 | 12:17 AM
Gary04Z06's Avatar
Gary04Z06
Default Re: R-D Camber Brace installed!!! (18carfan)
Camber Brace rocks!!!!! Great improvement to the handling. Cross Bar is another great addition!! Customer service is number one with Dave!! :cheers:
Old Aug 5, 2002 | 12:19 AM
The Example
Default Re: R-D Camber Brace installed!!! (Gary96LT4)
Man, now I really want to go put on the brace! I think I'll wait until after I get my car back from the bodyshop though...
Old Aug 5, 2002 | 12:37 AM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
Sounds like a good upgrade!! How much did this thing cost?
