84 AC Wiring Help Please
I'm sorting out some issues with my recently purchased 84 and am hoping you can help me with a question on AC wiring. I noticed a wiring loom with three plugs disconnected in the area of the AC compressor in the car. Here is a photo. From left to right I'll number them 1, 2 and 3.
So, I think plug 1 goes into the AC Low Pressure Cut Off Switch which I think goes here (the fitting is obviously broken and needs to be replaced)
Plug 2 appears to fit into the top of the AC compressor itself which I think is power
Now, plug 3 had me stumped until i looked at the back of the AC compressor and found something that looked broken at the pointy end of the screwdriver
Up close it looks like this
If anyone can tell me what goes in there, or even better if you have a photo or can give me a part number that would be great. I can see a cir clip in there so it must be a servicable part of the compressor.
Anyway, I just wanted to make sure I've got this correct and would appreciate any help you guys can offer.
Thank you.
The plug looks different to the one on mine, but I guess it could be because if is from a later model. Have no problem changing the plug over, just would like to make sure this is the item I need.
This switch turns the radiator cooling fan on when the a/c system high side pressure reaches approximately 238 PSI. Air flow across the a/c condenser is imperative to prevent high side a/c pressures from causing system damage (blown hoses typically). When the a/c pressures go above 350 PSI so does the temperature of the refrigerant on the high side. The resulting temperatures can also damage compressor seals. The switch in the compressor is a normally open switch, at 238 PSI it closes latching the fan relay.
Plug #2 is for the compressor clutch.
I believe a very early number for the "kit" might have been GM 6595212 and could be on a shelf at a local dealer for maybe a reasonable buy. The newer replacement is very expensive from GM/ACD. Your connector is still the OE single pin and if it is OK. eBay for the OE switch if you needed it. There may even be OE stock on some older dealers shelves.
Regards,
Darren
Based on your location if you could source maybe Wells or an Airtex part these would be the 2 pin kit I believe
Airtex: 1S2817
Wells: SW3013
I don't know that those will help but it's maybe options. Either of those numbers would be the switch (2-pin) and also the correct connector in one box or that's the way I interpret the information.
Both of those will give results also on eBay, maybe something closer to you. GOOD LUCK!
A High Pressure Cut-out Switch (HPCS), your #1, could be installed anywhere in your high side line, or in the dryer, by a competent a/c repair shop. For the wiring, the 12 v. comes from the Function Control Switch (FCS) (dashboard) to the Pressure Cycling Switch (located at your evap. coil, near the firewall), to the HPCS, to the Compressor Clutch (your plug #2). Your plug #2 also has a green wire that goes to the Computer Command Control System.
Your plug #3 could be eliminated by adding a relay that is actuated by the 12 v. from your FCS. This relay would be wired to provide a ground (earth) signal to the radiator fan relay. Your a/c repair shop may be able to add a "trinary" switch in the high side line, which will provide both the HPCS function and the radiator fan relay control function.
Thanks for the advice, I genuinely appreciate it. I'm trying to get the correct parts and pieces if they are available. It seems switch #1 is OK and easy to find, but just not sure about #3. If I can find them, I'd rather source and fit the correct parts. Its definitely not a concourse car, but it is still a pretty clean and unmolested example of an 84 crossfire and I'd like to try to keep it that way at the moment. I do however appreciate your helpful hints and advice. Keep it coming.
Regards
Darren
Attachment 47842108
I am on the same journey here. I have found the standard replacement parts are 2 wire or 2 pin where as the original is 1 wire one pin. I really don't want to install the old unit into the new compressor. Any suggestions on how to make the 2 wire work?
old broken single wire switch
old single wire connector
