My car is shrinking!?
Old Aug 2, 2002 | 11:06 PM
95wht6spd's Avatar
95wht6spd
Default My car is shrinking!?
It seems like my spoiler has been scraping more lately, so I measured the front wheel wells. The left side is 25.5", but now my right side is 24.5"! After lowering 2 years ago, the left was only about a .25" lower.
What do you think has happend? I want to find a 1" piece of rubber or polyurathane and put it in the left side where the pads where removed to lift the left side up and even it out. Where can I get this, Lowe's?
Any advice would be helpful.
Old Aug 3, 2002 | 10:05 AM
guywade's Avatar
guywade
Default Re: My car is shrinking!? (95wht6spd)
how old are your shocks? when they get old and leak the car usually sags lower, after i replaced my shocks, my car raised up about 1 1/2 inches, all around , good luck!
Old Aug 3, 2002 | 10:35 AM
95wht6spd's Avatar
95wht6spd
Default Re: My car is shrinking!? (guywade)
Funny, because I was just saying in anoother post that my shocks are fine and have about 73K on them. Maybe they need to be replaced, but it doesn't feel like it and they are not leaking that I can tell. I didn't think the shocks affected ride height, when you lower the front be removeing the pads the shocks don't keep the frame from lowering. Could it also be my spring is worn out?
Old Aug 3, 2002 | 03:54 PM
95wht6spd's Avatar
95wht6spd
ttt
Old Aug 4, 2002 | 12:30 AM
95wht6spd's Avatar
95wht6spd
Any more thoughts?
I want to get coilovers in the future, so I just need a temporary fix so I don't tear up the bottom of my car.
How can I tell if my shocks are bottoming out if I don't feel it? I push on the fron of my car and it only moves up and down a little, very stiff.
Old Aug 4, 2002 | 02:35 AM
TravisD's Avatar
TravisD
The shocks may be fine from a fluid standpoint, but the gas pressure is there to prevent foaming of the fluid during hard use, and this creates some "lift" as well. So they may pass a "bounce" test just fine still and still be bad.
Old Aug 4, 2002 | 09:31 AM
Rich B.'s Avatar
Rich B.
...after i replaced my shocks, my car raised up about 1 1/2 inches, all around...
Same here. Replaced Gabriel Red Ryder shocks with new Bilsteins; no difference in ride whatsoever, but car sits ~1 1/2" higher.
The taken-off shocks seem OK, too.
...But I'd rather have the B'steins...
Old Aug 4, 2002 | 01:04 PM
95wht6spd's Avatar
95wht6spd
Default Re: My car is shrinking!? (TravisD)
So how can I tell if they are worn out or not? I don't want to repalce them now if I don't have to, especially if it doesn't raise the car up evenly.
Old Aug 6, 2002 | 11:14 PM
95wht6spd's Avatar
95wht6spd
Well I still don't know if I need new shocks or not. Since my left front has become lower does this mean without a doubt I need new shocks or could it be something else? I don't want to replace the shocks now if I don't need to. :confused:
Old Aug 7, 2002 | 06:55 AM
tommelton's Avatar
tommelton
Swap the left front and right front shock to see if the shock is making the difference in height.
-Tom
To My car is shrinking!?
