Calling 383 drivers
Old Aug 3, 2002 | 10:38 AM
flynhi's Avatar
flynhi
Default Calling 383 drivers
I'm considering changing the hyd roller cam in my 383 from the Lingenfelter 219 to something else. Please post what you're running and comment on its performance.
Thanks,
Will
Sorry to invade the C4 forum with a q from my C3, but my power plant is basically a modified C4/ L98 so I'm lookin for help with you guys.
Old Aug 3, 2002 | 11:44 PM
flynhi's Avatar
flynhi
Default Re: Calling 383 drivers (flynhi)
ttt
Old Aug 4, 2002 | 02:27 AM
ZD1's Avatar
ZD1
I'm running a comp xtreme 276/281 deg at 112 deg sep (catalog) cam. It has a little lobe. What will really determine what a new cam will do, you'll have to consider the "system" CFM flow.
Old Aug 4, 2002 | 12:31 PM
J Z06's Avatar
J Z06
Default Re: Calling 383 drivers (ZD1)
I like the 219. it is a tried and true piece that works well, idles nicely and has a smooth flat powerband. I've run a 12.1@117 on street tires in my 383...and an 11.84-117 on drag radials spinning a bit. Cool fall air will net a new best I am thinking on slicks and skinnies.
There are a few 350 cars with afrs and the 219-sr clicking comfy 11 sec e.t.s so that cam can't be that bad. It also MUST be tuned correctly for maximum power.
Good luck!
Old Aug 4, 2002 | 01:06 PM
RocketSled's Avatar
RocketSled
I'm running a custom grind based on the ZZ9 cam with a more aggressive ramp profile:
214/228 112 LSA with 1.6 RR's
With the Superram, it should be good for 460+hp/490tq
To Calling 383 drivers
