I have some oil leaks in my car and decided to do some improvements while the engine was apart: timing cover leaking so I ordered water pump, optispark with cap and rotor, and comp cams double roller billet timing chain kit.
Oil pan leaking so I ordered melling high volume oil pump and new screen.
Valve covers leaking so I am thinking about upgrading valve springs and rockers and replacing valve seals also.
Here is the dilemma, from what I have read the timing chain might not work as a stock replacement, is this true?
If I get rockers should I get 1.5's or 1.6's? If I am reusing my stock camshaft.
Better to use stock lt4 springs or something else?
You will not be able to use a double roller on a LT1
Due to the OE gear drives your opti. As well as teeth to drive your water pump. You would need to eliminate the opti and use a electric water pump.
Clearance your timing cover and plug the holes for the water pump & opti.. 1.6RR on a stock cam gains very close to .030 lift. It makes a slight performance gain. LT4 behives will reduce some valvetrain weight. No worries here!! on high lift quick ramp grinds. Behives lack seat pressure & can create a very noisy valvetrain.
heres a few options you have related to the timing chain and valve springs.
If you buy a electric water pump, the ZZ4 timing set is more then strong enough single roller chain, but you honestly dont need anything more then stock with the stock cam. I would replace with a new timing chain and not think twice about it. You will not be able to run, nor do you need to run a double roller timing chain for a near stock application.
if you buy some 1.6 roller rockers, go ahead and upgrade your valve springs to either the LT4 or Alex's parts set of single valve springs, Otherwise stock ones will be fine.
From what the research I did when looking at using a double roller timing chain on my LT1. I found that opti should still work fine, but the factory water pump cant work. The water pump need to converted to an electric pump.
that is half correct, the vented opti will work fine, bu the non vented opti will not because the cam sprocket will not have the previsions for the early model opti drive shaft.
Thanks for clearing that up. It does not surprise me I had part of it wrong. I don't remember when I looked into it, but it was probably for the 97 Camaro I used to have.
Do you already the timing chain?
Yeah I called my local speedshop (who is normally knowledgeable)they suggested the chain I got, guess I need to go back make an exchange. Just wanted something of good quality.
So 1.6 rockers then, and Alex's valves? Should I just go for broke and get a mild cam and lifters then if I am going this far? I am still on the fence on keeping the car or buying c5 z06. I really want z06 but am thinking about buying another house so that might take precedence over it. My c4 is fun but hate my brakes and want more power without losing gas mpg, also wish it was 6spd. I guess I could always upgrade to grand sport brakes that may help. Too much trouble to convert to manual.
1.6RR will work just fine with the 93 LT1, and unless someone changed them it has aluminum heads.
I meant Alex's valves won't work. I've seen some comp cams complete kits that include camshaft, chain, springs, and lifters for around $300 stay away or are they ok for what I am looking to do?
They should work, but I am no expert of camshaft or valve springs. Maybe someone that knows will answer.
1st what is the mileage? If 100 or below.
You get purchase good quality 1.6RR and adjust the lash 1/2 - 3/4
Past 0 you will be fine!! The OE spings will handle this with ease.
Having said that, everything should work just fine but the chain. Cloyes did make an LT1 chain years ago (I built my 383s for my 93s in 95 and in 96). It was not double roller but had stronger gears with slightly deeper teeth. But it was hella expensive.
Here is a thread for people that are running the 3145 double chain you likely have.
I think I will go to speed shop tomorrow and make them exchange it toward the roller rockers and I will find a stock type chain from O'Reilly. Don't want to convert to electric water pump.
I got a used LT4 hot cam for $90 with springs and reused my stock lifters, cheap option for some extra horse power if you are already tearing it down to the timing chain, not much more work to stab a cam.
I keep toying with the idea to install a lt4 hot cam kit while my engine is apart. The kit seems pretty complete for $588 but does not include lifters or pushrods. What kind of power would this bump the car up to? I already have all the usual upgrades intake, exhaust, high flow cats, hypertech prom chip, etc.....
