Obscure Part Needed
Old Dec 3, 2014 | 10:07 AM
66cutlass's Avatar
66cutlass
Default Obscure Part Needed
Ok guys and gals. I have figured out the issue with the heat not blowing cold on my 1986 corvette. The plastic clamp/clip/fastener that holds the door rod to the actuator arm is broken.
I had to take the entire dash apart just to fix a piece the size of dice. The problem is that I cant find that piece anywhere. Does anyone have any ideas where it can be found?
It's getting cold and I need heat.
Old Dec 3, 2014 | 10:25 AM
WVZR-1's Avatar
WVZR-1
GM #20007898 and Corvette Central #454010
You may find the GM# on some dealers shelves, CC is in stock and there are other sources and "other" fasteners that will work.
The retainer for the other end of the rod is a more difficult find but it "can be". GM # 1224062.
Old Dec 3, 2014 | 10:29 AM
mcm95403's Avatar
mcm95403
Dude, you're amazing!
To Obscure Part Needed
