How to clear codes '88 c-4?
Old Dec 3, 2014 | 05:50 PM
Taps's Avatar
Taps
Default How to clear codes '88 c-4?
Hi,
I have a code 12 and a code 61 in my '88 corvette. I would like to clear the codes to see what redevelops. Any help would be appreciated. Thanks to all replies!
Old Dec 3, 2014 | 06:08 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Unhook the negative battery cable for 10 sec. or a better option is get a code reader you can get one for around $30 at an auto parts store. Once the battery is unhooked everything is reset and it takes about 30 miles to relearn.
Old Dec 3, 2014 | 06:29 PM
c4cruiser's Avatar
c4cruiser
A Code 12 simply indicates the start and stop of the code list. Even if you clear all other codes, the Code 12 will show up.
Old Dec 3, 2014 | 07:00 PM
Taps's Avatar
Taps
Thanks, does this mean the SES light is on always?
Taps's Avatar
Taps
Thanks, I'll pick one up.
Old Dec 3, 2014 | 07:18 PM
c4cruiser's Avatar
c4cruiser
No. If there are no trouble codes present, the SES light should be off.
Old Dec 3, 2014 | 10:03 PM
Taps's Avatar
Taps
[QUOTE=c4cruiser;1588402031]No. If there are no trouble codes present, the SES light should be off.[/QUOTE
I have a code 61. As best I can find out a code 61 shows on later year corvettes. (got 6 flashes,pause,one flash; 61)??
Old Dec 4, 2014 | 03:31 AM
Mark8801's Avatar
Mark8801
Code 12: No distributor reference.
No signal from the distributor (usually because it's not turning).
Old Dec 4, 2014 | 03:39 AM
Cliff Harris's Avatar
Cliff Harris
Error code 61 is not on this list, so that is a mystery:
http://forums.corvetteforum.com/1576116036-post35.html
You can clear the error codes by opening the ECM power connector for a second or so:
To How to clear codes '88 c-4?
