How much do leaky injectors hurt performance?
Old Aug 4, 2002 | 02:33 PM
kbklt1's Avatar
kbklt1
Default How much do leaky injectors hurt performance?
Kind of says it all in the title, I have a 92 so it's batch fire, when I start it after sitting for a bit and warmed up it blows black smoke for a sec.
The car seems to be very suggish through the whole power band, and I was hoping that it's due to the injectors leaking.
Thanks Guys
Old Aug 4, 2002 | 02:44 PM
severe-1's Avatar
severe-1
Default Re: How much do leaky injectors hurt performance? (kbklt1)
Leaky injectors should only affect idle. Broken injectors affect power curve. Sounds like you have other problems too. Any codes?
Old Aug 4, 2002 | 03:02 PM
kbklt1's Avatar
kbklt1
Default Re: How much do leaky injectors hurt performance? (severe-1)
nope no codes, it does have about 130,000 miles but no smoke or anything except on start up warm, sounds like it's time to try some compression tests and a leakdown test, it's got new pulgs and wires and a new cap and rotor in the opti.
I do know that it's pulling spark out between 4600 and 5500 something like 8-10 degrees. but I dont have diacom up and running yet.
But I think your right, there are some more problems to go with the injectors leaking
Thanks severe-1
To How much do leaky injectors hurt performance?
