LT1 starting problem
Old Dec 11, 2014 | 02:32 AM
jcvette1986's Avatar
jcvette1986
2nd Gear
Default LT1 starting problem
96 LT1 starts immediately a few minutes after shut down, not bad after overnight, but very slowly after shut down for a few hours. have replaced injectors, TPS, fuel pressure regulator, coil, coolant temp sensor, air temp sensor and maf sensor. Fuel temp passed all tests, any ideas. 56000 miles on car. don't have service records from previous owner
Old Feb 24, 2015 | 04:24 PM
Finalatom's Avatar
Finalatom
Did you ever figure out this problem? I'm having the same issue.
Old Feb 25, 2015 | 03:01 AM
jcvette1986
2nd Gear
No I think somehow ECM reads cold engine when it isn't or maybe leaky injectors. but injectors have been replaced and as far as I know all temp related sensors.
To LT1 starting problem
