What Size Wrench or Socket for Knock Sensor?
Old Dec 12, 2014 | 11:21 PM
Dr_Shakalu's Avatar
Dr_Shakalu
Default What Size Wrench or Socket for Knock Sensor?
Hey everyone. Well, the storm has finally passed in San Francisco so tomorrow I get a chance to replace my thermostat and flush my coolant system. I want to do it the right way by removing the 2 knock sensor. Does anyone know what tool is best to remove them? I also understand that some of the knock sensor is plastic and I don't want to break them. What's also the easiest way to get to them and do I need any type of thread sealant when I put them back in? Thanks in advance, Ed.
Old Dec 13, 2014 | 01:05 AM
Silver96ce's Avatar
Silver96ce
Should be 7/8 socket. Squeeze the sides of the wire connector to remove the connectors. You have a metal shield covering each sensor - IIRC should be a 10mm socket to remove those nuts. Don't use sealant to reinstall - it will affect how the sensor works. You need to use a torque wrench to reinstall them. They are to be tightened to 14 ft. lbs. If you overtighten them it could cause false knock and negatively affect performance.
Old Dec 13, 2014 | 01:36 AM
WVZR-1's Avatar
WVZR-1
I believe that M22 and 7/8 gets reported likely as frequently as each other. Either should work. That's also the same for most O2 sensors also.
Old Dec 14, 2014 | 09:16 AM
WW7's Avatar
WW7
You need to use a sealant on the knock sensor that's "Sensor Safe", it can be used on most sensors and doesn't cause you to loose ground..Most new sensors come with a hardend sealant already on them.....WW
Old Dec 14, 2014 | 10:14 AM
HlhnEast's Avatar
HlhnEast
If your KS is original, the likelihood of you getting it out without damage is minimal I would say. The inner parts of the KS will spin and the threaded portion will not. Go ahead and get another KS to replace your old one. As mentioned it will come with sealant already on the threads.
You will probly end up using a pipe wrench or something like it to grip the outside of the KS to get it out. I used a plumbing tool called a basin wrench to grip the outside and still be able to get in there to turn it. I already own a basin wrench as I am a plumber by trade. They are available at HD or Lowes.
Old Dec 18, 2014 | 10:50 PM
scooter mcfly's Avatar
scooter mcfly
My advice, and I think I just might start doing this myself, is to take your wrench, before you even touch that thing with it, to a priest and have him bless it. I swear, everything that touches my car causes something to break. Then something else breaks while trying to fix it, which causes something else to break. And so on. And so on...
Old Dec 18, 2014 | 11:31 PM
Dr_Shakalu's Avatar
Dr_Shakalu
I know what you mean!!! Check out my posts from today. Went to change my fuel injectors to the ones I got from Jon at FIC. They went on easier than I thought it would. Now's the part where things go wrong. Got a code P0507 high idle. Decided to clean my throttle body and IAC and now my idle is at 2500 rpm. Don't know if it's the IAC or the TPS that I accidentally took off. Have a new IAC and TPS on the way but now I learned that the IAC needs to be reset and the TPS might need setting also.
Old Dec 19, 2014 | 12:43 AM
tony58's Avatar
tony58
Would it help to spray them with Kroil penetrating oil several times before removing them?
Old Dec 19, 2014 | 11:16 AM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
Default when i removed my 85
i sprayed penetrating oil on the thread to block joint area...where it threads into the block...and then used a deep 7/8th socket on it. came out with some pressure but it wasn't an issue. perhaps the penestrating oil helped.
Old Dec 19, 2014 | 09:50 PM
don hall's Avatar
don hall
Sensor should come with thread sealant applied:
Take heed to what Silver96ce suggests about torque to 14 ft lbs.
VERY IMPORTANT.
Jack the vette to a level position....stay clear of the sensor holes as the liquid flowing out is nasty. Advisable to back flush through the
sensor holes several times to clear the area of sediment.
To What Size Wrench or Socket for Knock Sensor?
