Aftermarket stereo question
Old Dec 15, 2014 | 05:16 PM
videoprojeff's Avatar
videoprojeff
Default Aftermarket stereo question
Hey all! Looking for input on aftermarket stereo installation. I'm installing a Pioneer unit and keeping the stock Bose Gold speakers for now. I have the Metra harness for interfacing with the factory speakers. Doing a dry fit today, it all sounded great except for a thump when I changed sources, and even when tuning a station. Any thoughts other than dumping the Bose altogether? I came across a solution one day but can't find it again. Thanks!
Old Dec 15, 2014 | 05:57 PM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
Thats your amps, any time you change source power would have to be interrupted to keep them from making that noise, I believe that any time you hook any amp to the RCA jacks on your radio you will have the same problem. I am not sure but I think you would have to hook up some type of relay to solve the problem. you could try asking over on the audio section.
https://www.corvetteforum.com/forums...lectronics-20/
Old Dec 15, 2014 | 08:54 PM
dakota9498@hotmail.c's Avatar
Cruising
It has to do with the amps being on as the radio comes on or shuts off. When I initially installed my new head unit I installed a toggle switch in the remote/antenna wire so I could turn off the amps before shutting off the radio. Another solution is to wire in a delay circuit accomplishing the same thing. I only had the problem when the radio was turning off, I didn't notice it switching between sources. The only real solution is to replace the speakers and amps. I just went ahead and bought some aftermarket speakers and a small amplifier, I am in the process of installing it now. It wasn't too expensive, I found some good deals on Rockford Fosgate 5.25" and 6.75" components and a small Precision Power amp, it just takes a little time to run the speaker wire and install the speakers. Finding solid info on C4 audio is a real pain, especially spspeaker sizes. If you listen to what most people say then 5.25" will fit in the front, this isn't true without a lot of modification. I am playing around modifying mine now but may end up building an enclosure. The rears will accept 6.75" speakers perfectly.
Old Dec 15, 2014 | 09:23 PM
Hot Rod Roy's Avatar
Hot Rod Roy
Hey Jeff, by your handle, I'm presuming you know electronics. First question: What year 'vette?
Are you driving the Bose amps with your Pioneer head unit? If so, are you sure they are compatible? (I had to ask to be sure.) Or are you driving the Bose speakers directly from your Pioneer output amp? The Bose speakers in my car were 2 ohm impedance. My Pioneer amp would drive the Bose speakers, and sounded good, but the 2 ohm loads made the amp overheat! Not good. I found some Kenwood 4 ohm speakers that fit good in the Bose acoustic housings, sound good, and my amp is much happier!
Old Dec 15, 2014 | 10:34 PM
videoprojeff
Good guess! Yes, I know some. My plan was to use the pre-amp outputs to drive the amp/speakers. This is the recommended plan I've found using the Metra harness. An installer suggested using the speaker outs instead. He said he has done that successfully. Seemed counter-intuitive to me.
Old Dec 15, 2014 | 10:36 PM
videoprojeff
Mine is a '94. Sorry, forgot to add that!
Old Dec 16, 2014 | 04:09 PM
Cyclonite's Avatar
Cyclonite
I'm not familiar with the Metra harness. Is it just a connection block or does it have some adjusting capability?
When I put my aftermarket unit in I used a Scoche (IIRC) bypass harness that goes between the aftermarket unit and the Bose speakers. This has some adjustable controls to protect the Bose speakers from the non-Bose system. But... Mine's a 91 so there may be some differences between the components in your ride. (I know they relocated some components to behind the seat instead of under the dash.)
It's been quite a few years now since I've done it, but IIRC I got a lot of info from the Crutchfield website as well as the audio forum on this site.
Old Dec 16, 2014 | 04:57 PM
rimo's Avatar
rimo
I just rehauled my entire 1995 bose system by replacing everything. I originally had done the head unit and kept the bose speakers just like you did, but I heard the same pop in just about everything I did with my head unit. I also used the same Metra harness you did.
I ended up getting really annoyed with it and decided to pull all the original bose and run new wires to new speakers. I put 4" pioneer speakers in the front and 6.5" rockford fosgates in the back. The fronts required me to build a special bracket to fit the stock enclosure, but the back speakers fit in the stock enclosures perfectly. I did a little write up on my installation that is under my profile that goes into a little more detail. I'm very happy with the sound now, but am considering adding a powered subwoofer to fill out the lows.
Old Dec 16, 2014 | 08:53 PM
BLUE1972's Avatar
BLUE1972
I have an 85 that had the Bose. I now have a Pioneer head unit + 16 band equalizer and put the sub amps into the wells. I replaced all the speakers with higher power Quarts, Kustom and Kicker. There are 2 - 10" sub woofers in the rear storage compartment doors. I also added a 2" and 6" in each door.
If you cut the rear Bose speaker mount carefully and use 1/2" Oak wood you can mount 6X9's in the Bose location.(they are rated 1000 watts and the magnets just fit). I foamed the bass tube under the rear speaker and the new speakers sound better. I painted the wood black as that is the color of my interior and it hides any wood that shows. I originally put the rear speakers in the bose holders but they did not sound as good as they should have.
The setup is a little over kill esp with the woofers but I had the units and said "it will fit" You need to vent the well doors, the subs move a lot of air and thus keep the amps cool.
Yes the mirrors are useless at a 4 setting , but it sounds great at 2 which is my normal setting.
Old Dec 17, 2014 | 08:50 AM
videoprojeff
Cyclonite, There isn't anything special about the Metra harness. No electronics in it. It just has RCA's for the preamp outs, and the factory plugs on the other end. I'm going to try an installer's idea by getting a speaker level to line level converter. Word has it that the loud noise is caused by ground loop which the converters will resolve.
To Aftermarket stereo question
