DANA 44 VIPER GEARS
Old Aug 5, 2002 | 04:33 PM
GS345's Avatar
GS345
St. Jude Donor '11
Default DANA 44 VIPER GEARS
They will fit, right?! seems like the ring gear is bigger. I have read where you take a die grinder to the casting. If so where does it usually need it?
Thanks for your comments.
:cheers:
jeff
Old Aug 5, 2002 | 04:42 PM
STL94LT1's Avatar
STL94LT1
Default Re: DANA 44 VIPER GEARS (GS345)
I just bought a set of Dana OEM 4.10's for my car. They are essentially the same as the Viper gears with a different crush sleeve. These gears do have a larger ring gear, and on a few cars there has been clearance problems. The clearancing is minor if any, and can be fixed with a little die gringing. My gears are being installed tomorrow, I will let you know how it goes.
Old Aug 5, 2002 | 04:44 PM
scorp508's Avatar
scorp508
Are we talking about the company named Viper? Because there is a Viper manu. that makes gears. :)
Old Aug 5, 2002 | 04:47 PM
GS345's Avatar
GS345
St. Jude Donor '11
Default Re: (scorp508)
No, I am talking about the DANA gears from MOPAR performance for the Viper.
Old Aug 5, 2002 | 04:54 PM
STL94LT1's Avatar
STL94LT1
The clearancing problems usually occur on the top of the carrier or the back of the housing.
Old Aug 5, 2002 | 10:15 PM
RichS's Avatar
RichS
Default Re: DANA 44 VIPER GEARS (STL94LT1)
The Dodge Viper gears are made for a Dana 44 and bolt right in (Just need to be set up properly) There is no grinding involved. I put these in a few cars and they were always quiet, and have been holding up to alot of beatings :D
Old Aug 6, 2002 | 12:00 AM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
I am using Toms 4.11 for vette dana 44 rear end. Tom has them custom made and he seems to really know what he's doing. They run about 210 a set and use a crush sleeve. They are very quiet running and fit with no problems.
To DANA 44 VIPER GEARS
