Inside lights
Old Dec 22, 2014 | 09:15 PM
84vete's Avatar
84vete
Default Inside lights
I was driving and the lights went out on the inside the one on the shifter plate, the radio buttons, the info switches, and the heater controls also the wiper switch lights all are out the dimmer still turns on the interior lights i have no idea the reason this could be i checked the fuses also if you turn the car off and leave the lights on it will not ding to let you know that the lights are still on, need help figuring out this problem dont wan to take to a shop if its a quick fix i can do myself
Old Dec 22, 2014 | 10:50 PM
Hooked on Vettes's Avatar
Hooked on Vettes
Do the rear tail lights work?
Are you saying the 4 bulbs that provide the back lighting for the digital dash cluster LCD's still work?
Tail 10amp fuse is hot all the time. You should always measure 12 volts on it. Remove it and verify it's not blown along with the INST LPS 3 amp fuse.
When you turn the headlight switch to Head or Park, Tail fuse also supplies 12 volts through the headlight dimmer switch to the INST LPS 3 amp fuse that powers back lighting for the radio, hvac control head, digital dash back lighting, DIC, PRND indicator light, wiper switch and header map switch illumination.
Old Dec 23, 2014 | 10:03 AM
84vete's Avatar
84vete
It was the tail lamp fuse the only fuse i didnt check last night because i didnt think it would have anything to due with the inside lights so problem is solved thanks for the help
To Inside lights
