info lights
Old Dec 24, 2014 | 11:07 AM
bruce017's Avatar
bruce017
St. Jude Donor '13
Default info lights
88 l98 stock vette, the check engine or service engine light does not come on when I turn the key to on position, the only lights that come on are the low coolant, door ajar, and battery, when it starts they all go off, should there be more lights that come on so you can tell they are working, is the cel or sel on a fuse or relay, I could not find one in the fuse panel, thanks, 98,500 miles
Old Dec 24, 2014 | 05:14 PM
don hall's Avatar
don hall
Check your Owner's Manual for those lights that illuminate when you turn on the ignition.
Old Dec 24, 2014 | 05:51 PM
bruce017's Avatar
bruce017
St. Jude Donor '13
Default Info lights
I did, but could not find a fuse location, thanks
Old Dec 25, 2014 | 02:27 AM
Cliff Harris's Avatar
Cliff Harris
On my '86 the SES light is powered by the INJ1 fuse. The ECM turns it on and the wire goes directly between the two with no other connections.
You probably have a bad bulb. Check for that first and then look at the wiring between the ECM and the SES lamp.
Old Dec 25, 2014 | 12:07 PM
bruce017's Avatar
bruce017
St. Jude Donor '13
Default info light
ok, thanks, I will check the bulb
To info lights
