? for No Go
Old Aug 5, 2002 | 08:05 PM
lead_foot's Avatar
lead_foot
Default ? for No Go
Are the CC Pro Magnums self aligning so that you don't need to use guide plates? Do the fit with the center bolt valve covers?
Old Aug 5, 2002 | 11:23 PM
No Go's Avatar
No Go
Default Re: ? for No Go (lead_foot)
I elected to use non-selfaligning CC Pro Magnums on a 7/16" stud (1.6 ratio). I added set of Crane guideplates and hardened pushrods too.
Another forum member is going the 3/8" stud route with the CC Pro Magnums. These are offered in the self aligning option. This would save you on hardened pushrods and guideplates.
My rockers required some grinding of the stock LT4 plastic valvecovers. Very minimal and easy to see where-I just trial and errored it a few times and relieved the marked up parts with my trusty dremel. The valve cover material is very soft-obviously it was only internal, too. It shouldn't matter whether it is a 7/16 or 3/8 stud...now a 1.5 vs a 1.6 probably will.
