Is 1995 OBDII?
Old Aug 6, 2002 | 10:09 AM
Mervz's Avatar
Mervz
Cruise-In V Veteran
Cruise-In VI Veteran
Default Is 1995 OBDII?
I was wondering if my car is
1. Compatable with Autotap
2. OBDII complient.
I know in 95 they changed the chip to be on board, and not removeable. I assumed that was because they changed to OBDII. BUT, i was looking in the Mid america catologe last night just for kicks, and it said autotap was for OBD Cars 96+ only.
So, i'm confused... :crazy:
Old Aug 6, 2002 | 10:33 AM
scorp508's Avatar
scorp508
1995 is ODBI with an ODBII connector. Confusing huh? :D
Old Aug 6, 2002 | 11:15 AM
ZylaRace's Avatar
ZylaRace
Default Re: (scorp508)
Put another way,...
You need an ODBI scanner w/ an ODBI cable that has an ODBII connector. (Some call this an ODBII cable, but it's not.)
Old Aug 6, 2002 | 11:23 AM
Mervz's Avatar
Mervz
Cruise-In V Veteran
Default Re: Is 1995 OBDII? (Mervz)
jeez...
So Autotap would not work then? :crazy:
Old Aug 27, 2002 | 06:17 PM
Mike_88Z51's Avatar
Mike_88Z51
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
Mervz,
Well, not exactly. Most of the 95 vettes had OBD1 systems with OBD2 ALDL connectors. However, some late 95s had both OBD2 connectors and onboard system. It is my understanding that OBD2 was mandated by Uncle Sam for 96, but it wasn't illegal to be ahead of the deadline, so GM started phasing in OBD2 on some of the later 95s. The emmissions control sticker (usually on the radiator left side) is the final authority. Pop the hood and remove all doubt.
Old Aug 27, 2002 | 10:03 PM
Dragon2U's Avatar
Dragon2U
If you need a cable for your 95 I have one for sale in the "C4 For Sale" forum.
:seeya
To Is 1995 OBDII?
