'88 Digital ac/heat control
Old Jan 6, 2015 | 05:29 PM
czarredd's Avatar
czarredd
Default '88 Digital ac/heat control
Wanted to know if I can switch out a malfunctioning digital ac/heat control with a manual one? Thanks
Old Jan 6, 2015 | 07:59 PM
Matatk's Avatar
Matatk
The short answer is no. The systems are quite different.
Old Jan 6, 2015 | 08:01 PM
czarredd's Avatar
czarredd
Thanks...I thought not but thought I'd ask anyway. Thanks again!
Old Jan 7, 2015 | 02:38 AM
Cliff Harris's Avatar
Cliff Harris
I think it could be done, but it would be a LOT of work. The wiring harnesses are different and there are a lot of other parts that would have to be changed. For example, the vacuum for the various HVAC actuators is switched by the HVAC programmer on C68 cars but is switched at the HVAC control head on C60 cars.
Old Jan 7, 2015 | 07:45 AM
Red86Z51's Avatar
Red86Z51
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (stock) 2019
What is your issue...buttons that don't work? They're really not hard to repair. Post your exact problem and the help will come!
Old Jan 7, 2015 | 09:28 AM
czarredd's Avatar
czarredd
Well, when I turn on the unit...it doesn't blow any air whatsoever and the digital display will display a temp at first but then goes haywire. What needs to be done to get it functioning properly again? Thanks so much!
Old Jan 7, 2015 | 11:19 AM
Red86Z51's Avatar
Red86Z51
These controllers can exhibit some strange symptoms when the connectors between the faceplate (with the selector buttons) and the head unit motherboard start to lose contact. Below is a link that I used to repair mine when it was started acting up. I did not go to the extent of the repair in the article, I simply removed the control head unit, disassembled it and cleaned the contacts on both the faceplate and motherboard side. I used a small springhook to reform the connectors on the faceplate side so that they would make tight contact with the pins on the motherboard. I did this over a year ago and have had ZERO issues with mine since. These contact failures are a well known issue with our cars equipped with C68 Electronic Climate Control (ECC). I completed the whole process within an hour.
Link --> Repairing the C68 Electronic Climate Control
Old Jan 7, 2015 | 01:03 PM
czarredd's Avatar
czarredd
Ok thanks. Would a faulty contact affect the air not blowing? I guess it could if the button to activate the air/heat isn't being activated...correct?
Old Jan 7, 2015 | 03:06 PM
Red86Z51's Avatar
Red86Z51
Absolutely. The head unit is in charge of every aspect of your HVAC. After you've gone through the cleaning, terminal reforming, and reseating of the motherboard -or - adding the wires as per Batee's repair outline, please come back and post your results.
I'll stay tuned!
Old Jan 7, 2015 | 03:15 PM
czarredd's Avatar
czarredd
I'll stay tuned!
Will do...thanks again!
To '88 Digital ac/heat control
