anti-lock brakes
Old Aug 6, 2002 | 06:27 PM
j.k.ritter's Avatar
j.k.ritter
Cruising
Default anti-lock brakes
anti-lock warning light has started to come on. don't know if it's a coincident or not --but battery failed at the time the light started coming on. it still goes the self test at 4 miles per hour. after the self test occurs at least twice, the light comes on. where does one start looking to repair. i know there are three relays--is one more likely than the others to fail---could the low voltage when the battery failed burn up a relay. any help would be appreciated.
Old Aug 7, 2002 | 10:59 AM
dlmeyers's Avatar
dlmeyers
Default Re: anti-lock brakes (j.k.ritter)
Head for the archives. Search ABS.
There are some excellent posts trouble shooting pre 90 ABS systems. The 90 and above ABS module allows for trouble codes.
Let us know if you can't find anything.
dlmeyers 90 coupe zf6 3 speed shocks
