L98 and LT1
Old Aug 6, 2002 | 07:40 PM
keekster's Avatar
keekster
Default L98 and LT1
Is it worth the extra money to buy a car with an LT1 if both cars have similiar miles and condition ?
Old Aug 6, 2002 | 07:45 PM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
Default Re: L98 and LT1 (keekster)
The LT1 will be a newer car so yes, I would get the latest model all else being equal. The LT1 has a higher hp motor which is a plus as well.
Old Aug 6, 2002 | 08:19 PM
Bat Man's Avatar
Bat Man
Default Re: L98 and LT1 (AquaMetallic94LT1)
Get the LT1, its worth it. Really a more smooth engine, higher peak HP, real nice.
Either way you can't lose though.
Old Aug 7, 2002 | 12:10 AM
vader86's Avatar
vader86
Always buy the newest you can afford.
Old Aug 7, 2002 | 02:13 AM
Togo's Avatar
Togo
both have their setbacks.....you need to decide what YOU want and what you are going to do with it!!!! :cheers:
Old Aug 7, 2002 | 07:38 PM
keekster's Avatar
keekster
Default Re: L98 and LT1 (85_togo)
What do you mean what I want to do with it ? What would be the differences ? I am going to build it out is oone cheaper to gain HP ?
Old Aug 7, 2002 | 09:13 PM
jcazin's Avatar
jcazin
there are plenty of post regarding this subject in the achieves, but as always, it comes down to how much you want to spend vs how fast you want to go- there are no shortcuts. My own opinion was to enter low with a L98, which can be tweaked to go as fast as I want to go for under $5000, but to each his own.
Old Aug 7, 2002 | 10:18 PM
Sharky Guam's Avatar
Sharky Guam
Default Re: L98 and LT1 (jcazin)
I would say that it is cheaper to mod the L98. However, it is better to buy the newest vette possible to achieve a better driver.
:seeya
Old Aug 7, 2002 | 11:20 PM
Aaron71771's Avatar
Aaron71771
LT1 all the way baby. It's just a better engine.
Old Aug 8, 2002 | 12:16 AM
ZD1's Avatar
ZD1
If you are going to build it for power starting with an 85-86 block with the 2-pc rear seal will give you the best upgrade potention since that block has more stoker (affordable) thant the later l98's and LT1.
Of course you could just buy a late ZR1 (405HP) and add the basic bolt-ons for cost savings. ZR-1s with miles are running 20-30K. But for 450 HP (with goodies) 20-30K isn't all that bad.
Then again the LS1 guys seem to have a good time with just bolt-on packages plus cam and heads....
and on and on and on...
To L98 and LT1
