AAARRRRGGGG!!!!! striped sparkplug threads!!!
Old Aug 6, 2002 | 08:28 PM
ASRoff's Avatar
ASRoff
Default AAARRRRGGGG!!!!! striped sparkplug threads!!!
Does anyone Know what the tap size is? I know its a 14mm but what is the thread count? :mad
Old Aug 6, 2002 | 08:54 PM
jefft84's Avatar
jefft84
Default Re: AAARRRRGGGG!!!!! striped sparkplug threads!!! (ASRoff)
14X1.5 MM
Most of the parts stores sell taps designed just for plug holes.
TIP after recutting/cleaning the threads crank the engine with out the plug installed to blow out any particles that may have fallen into the cylinder.
Old Aug 7, 2002 | 10:06 AM
Steel Blue 91's Avatar
Steel Blue 91
Default Re: AAARRRRGGGG!!!!! striped sparkplug threads!!! (jefft84)
Also, coat the thread chaser with grease or Vasoline. This will help reduce the amount of debris that falls into the cylinder. If you have access to an interior detail vac with a thin, flexible pick-up tube you can push the tube into the spark plug hole.
Old Aug 7, 2002 | 04:12 PM
ASRoff's Avatar
ASRoff
Default Re: AAARRRRGGGG!!!!! striped sparkplug threads!!! (Steel Blue 91)
Allready planed to do both ;) But thanks for the tips!!! and thanks for the thread pitch. All the auto stores around here only sell thread chasers not the actual tap. I'm going to production tool supply after work!!!
Old Aug 7, 2002 | 10:31 PM
Jay Axson's Avatar
Jay Axson
I feel for ya bro. I stripped my crank bolt when putting in my hotcam. Fortunately I only mangled the threads and didn't break them. Good luck.
Old Aug 7, 2002 | 11:32 PM
ASRoff's Avatar
ASRoff
Default Re: AAARRRRGGGG!!!!! striped sparkplug threads!!! (Jay Axson)
:D :D :D :D It Worked :D :D :D :D
Old Aug 8, 2002 | 12:26 AM
chucks88's Avatar
chucks88
Tell us how you really feel :lol:
Good job :yesnod:
Old Aug 8, 2002 | 08:53 AM
Steel Blue 91
Default Re: AAARRRRGGGG!!!!! striped sparkplug threads!!! (chucks88)
We may not be experts, but we all stayed at a Holiday Inn Express last night.
Way to go.
Old Aug 9, 2002 | 01:16 AM
jefft84's Avatar
jefft84
Guys, very sorry i misquoted the thread pitch. :mad PLEASE FORGIVE ME The correct size is 1.25mm I checked my tap at work to day. By the way Napa sells a really good tool called a back tap it inserts past the threads and cuts on the way out removing all the crud with it. I believe Snap On sells them also.
To AAARRRRGGGG!!!!! striped sparkplug threads!!!
